Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: remove password hitachi
PostPosted: November 9th, 2015, 10:40
Several errors when I run Victoria, as administrator
When started , I can not select PIO mode
Also I leave a screenshot of mistakes , which are many .
Does it fix?
PostPosted: November 10th, 2015, 16:20
Spildit wrote:
- You can't properly load victory because of I/O DRIVER. This is most likely because you are running 64 bit version of windows instead of 32. Victoria should work just fine on windows xp 32 bit.
- You have pending sectors but not relocated sectors. Meaning most likely bad ecc or header on the sector. Doing erase will either write correct info to the sector header and ECC making it usable again or move the sectors to the G-List (reallocated sector count - at 0 right now).
- You will need to use either another version of 32 bit windows or MHDD for PURE DOS and erase the drive. Alternatively you can use internal secure erase but again all will have its own risks.
Regards.
thanks, I 'll try to install Windows XP 32 on another computer
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Pandemicc and 459 guests
