 Post subject: HDD powers up, clicks X times and stops spinning
PostPosted: January 29th, 2015, 18:35
Hey guys. Just to not confuse anyone, this is not the same HDD that i posted about on my first thread here in these forums.
This Seagate st31500341as HDD stopped working a few days ago, and even tho the OS (windows) wasnt running from this hard drive, it slowed down the whole system so i had to unplug. It slows down a lot the boot proces and the system in general if i plug it in again. Windows Disk Management or PC BIOS do not see this HDD anymore.
When i start the computer this broken HDD will start spinning, than it will make "tic tac" noises, it will tic tac 22 times (11 tics and 11 tacs) and than it stops spinning. This process takes like 30, 40 seconds from when i power up until it stops spinning.
Even tho it stops spinning, it still heats up as if it would if it was working.
Could anyone pinpoint the problem with this info i gave? Since it does exactly the same thing when i power up, maybe someone can tell what the problem is? Any chance replacing the PCB board would fix this?
Please let me know, thanks a lot!
 Post subject: Re: HDD powers up, clicks X times and stops spinning
PostPosted: January 30th, 2015, 2:55
Click 11 times and spin down = bad beads
NOT DIY :-(
PostPosted: January 30th, 2015, 5:03
Hey pcimage, you mean bad "head" ? Or "beads" really?
Thanks!
PostPosted: January 30th, 2015, 6:22
Hey! ;)
With my ST3000DM001 happened the same few days ago. I think it is Heads, if the data is important to you, you should call a PRO for recovery, and should NOT turn it on anymore.
PostPosted: November 21st, 2015, 23:21
Hey,
My ST31500341AS has the seme problem here.
How to fix it? Should I change the heads?
thx!
PostPosted: November 22nd, 2015, 2:46
i don't think so
send it to a pro
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 40 guests
