 Post subject: WD2500JS Hawk
PostPosted: December 8th, 2015, 17:35
This drive has lost the ROM (client removed it with pliers). We have a donor board attached and can load the drive into PC3K utility. The drive will not ID (factory alias) but will read all modules. Modules for a ROM rebuild are not available. I have tried several ROM's but cannot get any further. I have tried loaders (inc from the drive itself) but cannot get the drive to ID. Any advice would be appreciated.
 Post subject: Re: WD2500JS Hawk
PostPosted: December 8th, 2015, 18:04
Banned User
Use wdr to regenerate rom.
PostPosted: December 8th, 2015, 18:07
Keep searching for more ROM codes to try. Did you look in my firmware database?
PostPosted: December 8th, 2015, 19:03
I haven't got to the DB yet. I had about 20 ROM images to try and I have been churning through those first :-)
PostPosted: December 8th, 2015, 19:19
What's the FW version? Check module 11's header info, also 1F, 2F, etc.
http://www.datasaversllc.com
PostPosted: December 8th, 2015, 19:30
Hi Jono - 1098E
PostPosted: December 8th, 2015, 19:33
Thanks for you help guys, eventually found a matching ROM :-)
Users browsing this forum: Google [Bot] and 228 guests
