 Post subject: WD10S21X-2R1BT0-SSHD-8GB
PostPosted: January 6th, 2016, 13:50
Hello!
As in topic, this drive spin up normally, calibrate and ID.
But all sectors shows ABRT.
Any thoughts ?
Thanks in advance.
 Post subject: Re: WD10S21X-2R1BT0-SSHD-8GB
PostPosted: January 8th, 2016, 21:31
Any info on background failure from the customer? Any suspicion of anything?
PostPosted: January 9th, 2016, 5:06
The customer said the laptop hang and forced to restart. That's all.
No suspicious things happened
PostPosted: January 9th, 2016, 12:46
I don't have a lot of experience with his WD series of products as they have not began failing in large numbers yet, but I am curious.
Is the drive spinning when reading LBAs (ar even at all)? If not, then the problem at this point could be at this time relegated to the flash component. Or firmware. Not sure of this drive's architecture, whether firmware is also loaded in flash (I doubt it though, but this is likely to happen sooner or later, if not it is already in some new drives)
PostPosted: January 9th, 2016, 13:49
Ahmed chatted with me yesterday and said he solved this case .Might be he can shed some light
PostPosted: January 9th, 2016, 19:51
Yes sir. Case solved.
Thank you very much my friends for trying to help me.
PostPosted: January 10th, 2016, 2:56
Hi Everyone ,
Does Anyone Have a Experience How This HDD Is .Specially Compared To Velociraptor 10,000 RPM .I am Leaving Aside SSD's For The Time Being .
