 Post subject: Seagate Barracuda 7200.10 won't spin
PostPosted: January 19th, 2016, 2:01
hi everybody !
someone stole my laptop and i was using an hold hard drive as back up but my back up is not working !
seagate barracuda 7200.10
320gb
firmware 3.AAF
site code TK
use with external enclosure ..i tried different drive and they all work ,so enclosure out of the equation.
what happened ?
nothing special it was in box in a warm and dry place
symptoms : once it s plug and turn on the green light is lighting but no noise ,no spin Nothing happen.
i removed the PCB for examination : no sign off burn or over heating ,i cleaned all the connections no dust no rust or oxidation
the 12v is coming into the board and it s going to the 3 pin motor connectors
so i guess the motor is receiving power ! but dont spin
i opened the cage and the disk spin manually so its mechanically working...
does the motor need an information from the pcb to start running ?
or receiving 12 v means pcb send the information and the motor is just dead ?
i did my best and im not able to figure it out !! need experienced people
i found a seller to buy the exact same pcb but before spend 50$to replace something who in fact working
i would like to be sure that it s not the motor .
if you have any suggestions it ll be help-full ..
i can send pictures if requested.
thanks a lot for your attention ..
A
 Post subject: Re: Seagate Barracuda 7200.10 won't spin
PostPosted: January 19th, 2016, 2:54
Usually bearing get stucked on these series.
You can try another Pcb (5% chance), stucked bearing (95%).
If it's bearing you'll need pro help.
http://www.rescue-it.se
PostPosted: January 19th, 2016, 3:04
PostPosted: January 19th, 2016, 3:57
PostPosted: January 19th, 2016, 4:02
after opening the lid my advice is, if the data is important take it to a pro. and by pro i mean a DR pro not a computer technician.
PostPosted: January 19th, 2016, 4:39
Does this mean you opened the drive?
Its safe to try a new PCB as long as firmware matches.
In all my time of data recovery i have only once seen a dead motor, its very rare that the motor is faulty but could be possible.
Spindle seizure is qute common on this model of drive. So common that HDD Surgery developed a tool especially for these drives.
You will need a pro for this one to free the spindle, or at worst perform a platter swap to a donor.
Web: https://www.day1data.de
PostPosted: January 19th, 2016, 4:58
"The disk spin manually" means that the spindle is NOT seized.
PostPosted: January 21st, 2016, 17:27
Hey thanks for all your answer , the data are not so valuable so i dont want to paye 200$ or more for recovery..
im more interested to understand what is wrong.. so i might change the pcb . to exclue that possibility and focus on what is left if it doesnt work !!
the weird thing is that 12 v run to the pin connector of the motor i just dont understand how is it suppose to spin when it already receiving power ?
doest it need a signal from the PCB ?
thanks for you support !
Users browsing this forum: Majestic-12 [Bot] and 243 guests
