Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD resurrection after drop?
PostPosted: January 20th, 2016, 22:07
revis wrote:
if there is a chance to make it work again, knowing of course that it will be not a drive where to store important data,
I think you got it all wrong
we are talking here about a disk who fell
so, most likely you'll have to replace the HSA, which I find it hard to believe that you gonna pull it off
not to mention the tools and knowledge you'll need before AND after replacing the HSA
and even if a miracle is gonna happen against all odds - which i find it very hard to believe - and you'll get to a stage that it's gonna recognize in BIOS, it will not last that long to be able to take out your data.
and if the miracle will - for some reason - continue, it will die much faster than you think.
and if the miracle will continue, then go buy a lottery ticket
PostPosted: January 21st, 2016, 6:16
Online
instead of wasting money on a donor, send that amount to my paypal :)
it has the same effect on your side.
(joking of course)
PostPosted: January 25th, 2016, 16:08
Thanks for the encouragement :P if I win that lottery I'll give you a part :D
(joking of course)
:D
PostPosted: January 25th, 2016, 16:22
@revis, when you had the cover off, did you try rotating the platters by hand? (I hope you didn't touch the platters.)
Users browsing this forum: Google [Bot], pepe and 35 guests
