 Post subject: Mask Explanation Needed
PostPosted: January 25th, 2016, 18:53
Anyone know of a resource to fully explain the Masks used in NAND recoveries (eg 0xFFFF) when converting data by using block numbers (eg 0000).
Thanks.
 Post subject: Re: Mask Explanation Needed
PostPosted: January 26th, 2016, 9:35
It is a bit mask.
https://en.wikipedia.org/wiki/Mask_(computing)
Specifically, it utilizes the AND operation.
PostPosted: January 26th, 2016, 12:17
MattM wrote:
It is a bit mask.
Many thanks :)
PostPosted: January 27th, 2016, 2:10
If you do a search there is somewhat of an explanation, in true minimalistic style, in a convo between Sergey and Jeremy. http://flash-extractor.com/forum/viewtopic.php?t=4176 Read both pages.
PostPosted: January 27th, 2016, 12:44
