 Post subject: WD30EZRX-00D8PB0 FW Problem - Remove Password - PC3K
PostPosted: February 11th, 2016, 6:15
Hi Guys,
I have this drive WD30EZRX-00D8PB0 that when i connect in PC3K, its normal became "Ready", autodetect the family is Diablo 3S but when i click "Utility Start" it becomes a new windows with options Open HDD and Remove Password. But neither work and i can't acess the FW.
Does any one have this problem?
I appreciate reply's.
Best Regards,
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: WD30EZRX-00D8PB0 FW Problem - Remove Password - PC3K
PostPosted: February 11th, 2016, 15:30
Is the drive from a MyBook? Might be a SED locked drive, if so check out this: http://blog.acelaboratory.com/pc-3000-h ... rives.html
good luck!
030 Datenrettung Berlin GmbH (Germany)
HDD, SSD, NAS, RAID Datenrettung - 030-datenrettung.de
PostPosted: February 11th, 2016, 18:12
These aren't SED.
PostPosted: February 11th, 2016, 18:27
@pcimage: Just had one Diabolo3S last week that was locked, but it was a WD30EFRX-68EUZN0 that behaved just like the one the op has and came from a mybook.
PostPosted: February 11th, 2016, 18:51
Interesting :?
I've never come across one with this issue (yet) but have seen plenty of xxD8PB0 drives, 3 this week so far.
So far they have all been either bad heads and/or FW issues (slow responding etc..) and I'm pretty sure they aren't actually SED drives. But I'm gonna have a play to see if I can replicate the issue :-)
PostPosted: February 11th, 2016, 19:19
Short TV9-TV10 on PCB to access FW, load overlays, and on mod02 do a drastic method WD slow issue fix.
PostPosted: February 11th, 2016, 23:08
pcimage wrote:
Interesting :?
Sean ,
Its xxD8Pxx family .Secondly as it has come from a my book to PCN might be its SED .Typically it should not be
PostPosted: February 12th, 2016, 8:36
This drive is SED :) i was able to remove it and decrypted the drive, because was a WD external case that are encrypted by factory. Recovered successfully. Thanks for the reply's. Regards.
Users browsing this forum: Google [Bot] and 75 guests
