 Post subject: Kind ROM request WD10EADS-22M2B0 board 2061-701640-700 02PD1
PostPosted: March 11th, 2016, 10:36
Hello to all of you
The board of the drive in subject is really much dead
I can't read the ROM neither through terminal
Unfortunately it is a board WITHOUT U12 so I have no info about ROM version.
I've tried many in my DB and from the hddguru stock
So if you kindly want to help providing the .bin ROM file, please verify the FULL board number
The drive is made in THAILAND it is manufactured OCT 2009 and the s/n is WCAV5269XXXX
needless to say DragonFly2
Thank you so much in advance for any help
 Post subject: Re: Kind ROM request WD10EADS-22M2B0 board 2061-701640-700 0
PostPosted: March 11th, 2016, 11:19
Try this, from nearest s/n I have (WCAV5230xxxx)...
ROM.rar [175.29 KiB]
Downloaded 1126 times
PostPosted: March 11th, 2016, 11:21
Thank you M8!
PostPosted: March 11th, 2016, 11:55
Ouch!
Unfortunately I don't have the right donor board
All of mine 2061-701640-xxx are equipped with the U12
I need one U12-less
I'll update you thank you
PostPosted: March 12th, 2016, 13:19
Thank you Spildit
But I must admit this confuses me.
I've tried a bunch of ROMS from my db and from hddguru files, but maybe I do something wrong
In fact I got also this info: "write a bare ROM then write needed modules"
I never had to deal with this before and also acelab support doesn't help so much with this case.
What do you kindly mean?
P.S. There is no way to read the original ROM, I have 6.0.16 and also through terminal, no way.
Thank you for some more details
PostPosted: March 12th, 2016, 13:28
This is the point
I have only two boards with same number but different revision.
Both have the U12
So i'm not sure they are good.
With both I have the drive that clicks and spins off.
PostPosted: March 12th, 2016, 13:32
Rebuild from SA is my original goal :-)
The problem I face is the drive that don't keep on spinning
and blocking SA access I suppose makes no sense if the board basically "points head to the wrong place"
Though the two board I have are not from a 22M2B0
PostPosted: March 12th, 2016, 13:35
So I tried to burn ROMS from various 22M2B0
But also writing those ROMS (which some are not fine and go to brick the board) no way, still the same behavior
Drive clicks and spins off
Ok maybe that when the board blown off (it is exploded the head/spindle controller), also the heads preamplifier went dead too.
PostPosted: March 12th, 2016, 13:49
Yes
That was the final option.
I've located one with same board label
Thank you really much for the suggestions
PostPosted: March 12th, 2016, 14:03
On WD drives with burnt VCM highly likely also have burned preamp.
You need firstly check +-5V resistance.
PS. WD drives after 2009 year doesn't contain in SA modules for rebuild ROM.
PostPosted: March 12th, 2016, 17:51
in the link provided above by "Spildit"
Spildit wrote:
Get a compatible PCB. Drive should spin up ok, then try to gain access to SA so that you can rebuild original ROM from modules on SA.
http://blog.acelaboratory.com/pc-3000-f ... -v6-x.html
the guinea pig drive were used by ace lab was manufactured on 05 OCT. 2009
PostPosted: March 13th, 2016, 1:31
Corsari wrote:
Hello to all of you
Well,
Have You Tried This -> http://ts.acelaboratory.com/index.php?/ ... connection .Also Note That When You Power On The Board Inspect All IC With Fingers And See If Something Is Getting Too Hot If It Does Its Short If Not You Have a Chance
PostPosted: March 13th, 2016, 9:21
Hello Amarbir
I've written that above
where I've written that the board is dead so much and also the attempt to read through terminal didn't work.
PostPosted: March 13th, 2016, 13:09
If the MCU survived the surge, then I suspect that retrieving its embedded ROM contents may be as simple as adding two external supplies (+2.5V and +1.2V) and asserting the POR (power-on reset) signal to the MCU.
PostPosted: March 13th, 2016, 15:50
Assuming that it would work and assuming you wouldn't jtag to the MCU then you would still need for either the TX/RX X-Modem component of the circuit to be functional or for the SATA components to be functional in order to issue VSC to the MCU and extract the ROM in PSV/Kernel mode.
All those components are part of the MCU. JTAG wouldn't be required.
PostPosted: March 13th, 2016, 16:32
The voltage test points would be easy to find. I haven't checked my PCB, but I think the attached image is correct.
NPOR is probably one of the 8 signals that run between the SMOOTH IC and the MCU. It is probably high when the supply rails are OK and low when they are out of spec. That's a matter for experimentation, though. I would use a 1K resistor to test each of these signals, either as a pullup to Vio or pulldown to ground
PostPosted: March 13th, 2016, 17:39
The OP hasn't provided a photo or the results of any TVS diode tests, so it's not possible to say whether the surge hit the +5V supply or the +12V supply. A 12V surge is survivable.
PostPosted: March 14th, 2016, 1:59
The first (and unique at the moment) test we did,
has been to completely remove the SMOOTH ic.
Since it made no difference, we abandoned the idea to go further with diagnoses of the board.
But all above is really interesting and requires some tests and measures.
PostPosted: March 14th, 2016, 2:16
The SMOOTH IC generates the supply voltages. Without it, you get 0V for both Vcore and Vio.
PostPosted: March 14th, 2016, 2:31
Uh-oh :-)
Never dealt with those type of researches, thank you Fzabkar you are always an authority in matter of knowledge.
That faked our test so, since we thought other components could been burned, while SMOOTH ic could be the unique one so.
Instead we thought (but for a while only) to feed power to the Marvell IC alone, but without schematics...
now you provided important hints.
Thank you
