Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Seagate 2 GB ST2000DM001 Barracuda 7200.14 Recovery Effo
PostPosted: May 6th, 2015, 23:45
Alexii,
I have a 3tb that is doing the almost the same thing. I swapped the heads and how its runs without shutting down but gives "Sim Error-Remaining in BootFW.
Perform a double download without a power cycle". Did you get this?
I too can't get into terminal. Also, What do you mean by 'spam' CTR Z?
PostPosted: November 21st, 2015, 18:57
I'm amazed I found others with the exact make and model hdd and with exact symptoms.
Back in March, 2015 this issue happened for me and I assumed it was a mechanical failure but professional data recovery is way out of my price range.
I found this website because I searched on my PCB model for shorting the Read channel pinholes. I purchased a kit with a serial USB adapter and software specifically to diagnose Seagate hard drive's using the Terminal prompt.
I cannot make Terminal prompt because I believe my adapter is not providing the needed low-voltage TTL serial interface. I need to learn how to build this low voltage interface in beginner language. I doubt I have time to wait for this same part to be shipped to me as I'm under considerable pressure with about six more days to fix this hard drive.
Can anyone point me to a well done "how to make a low-voltage TTL serial interface" that involves going to the local electronics store for the parts? Think of my knowledge level as in Kung Fu Panda.. "There is now a level 0" and I need instructions along those lines. I'm smart and can figure things out if instructions are well-written.
Thanks very much for your time and help,
Jonathan
BARRACUDA 7200.14 FAMILY
SN: Z1F2QLHX
Model: ST300DM001
PN: 1E6166-570
FW: CC45
Date: 13364
Site: TK
PCB: 100687658 REV C
PostPosted: November 21st, 2015, 19:24
Thank you both very much for the quick responses. This is a bit discouraging to hear of the difficulty level.
I will read all of this and keep pushing forward to see if I can see any success.
Thanks again and I'll only post back here if I have further questions or if I can state any successes. :)
Jonathan
PostPosted: November 28th, 2015, 20:12
Background: The hard drive does not/has not made any clicking sounds. The hard drive powers up every time but will not be recognized by any computer's BIOS.
Update:
The USB TTL Adapter I purchased is using the correct 1.8V as I confirmed with the manufacturer that the adapter was designed for the range of 1.8V to 5V.
I still cannot get a Terminal Prompt but I was able to use the software to read the boot messages. I was told that this information says I have head failure.
Boot 0x40M
Spin Up
FAIL  Servo Op=0100 Resp=0003
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1E80 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 81E7 0293 64AC 45C2 A77C DBB6 9CCE 428F 8D4C CA20 0000 007F 000A 0000 FFF7 0004 0010
ResponseFrame 24C0 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 81E7 0293 64AC 45C2 A77C DBB6 9CCE 428F 8D4C CA20 0000 007F 000A 0000 FFF7 0004 0000
Four Questions:
1. What is a fair estimate of total cost that a data recovery business would charge?
2. Do you have 3-5 suggestions for data recovery businesses to contact?
3. Are there any recommended books that would help me learn how to repair the heads of a hard drive and recover the data? (Or is everything on YouTube?)
4. What hard drive information do I need to use to find a donor drive?
(This is a repeat of the information I posted earlier)
SN: Z1F2QLHX
Model: ST300DM001
PN: 1E6166-570
FW: CC45
Date: 13364
Site: TK
Thank you again for your time and consideration of this situation.
Jonathan
PostPosted: November 29th, 2015, 6:51
Hi jonathan_HPC,
1. 1000$-2000$ (If there is media damage might be more)
2. Do not know one in Texas, sorry. But other forum members might help out.
3. First, you can not repair heads. One can try to clean them but when they are damaged, you would do a heads-swap. For a heads-swap you need much practice, the right tools and a lab. That's nothing you can learn in a few days. Do not trust in youtube. There are some videos and some are ok but they will not help you in your current situation.
4. Match: SN (first 3), Model, PN, Date (as close as possible), Site. If all matches you will need special tools to patch adaptives and you always need some kind of luck on 7200.14 because even if anything seems fine (matches) there might still be issues you will have to fix.
Best regards,
PostPosted: March 23rd, 2016, 7:56
i have same Disk St2000DM001 - same problem, i can entert f3 t .
Then i enter
/T
i4,1,22
F009A,C1
F00E2,91
F00EC,B0
/1
N1
Disk is visable by Bios and Ubuntu.
I run ddrescue -n -f /dev/sda /dev/sdb (another 2TB disk) but ddrescue is works wery slow, about 200kB/s
How to speedup?
Sorry my english is bad:D
PostPosted: March 23rd, 2016, 8:20
Lesiex wrote:
How to speedup?
hardware imager might
PostPosted: March 23rd, 2016, 10:37
no i have only desktop and ddrescue :)
PostPosted: March 23rd, 2016, 10:42
try it in reverse mode with -R switch.
Data Recovery Pakistan
PostPosted: March 23rd, 2016, 10:44
Head swapped a ST2000DM001 yesterday myself too. Only had around 1500 bad sectors in the end which were isolated to a few areas and only affected a few files. I'm actually starting to like these DM drive cases now that I fully understand most of their quirks.
PostPosted: March 23rd, 2016, 17:07
1 .how to swap heads?
2. When i run ddrescue is running abount 260kb/s - restore 5000MB and hang
i start from 0GB , 20GB and is the same - when i connect console to f3 T and /1 > N1 - hdd works again.
PostPosted: March 23rd, 2016, 18:03
Spildit wrote:
Try :
F"RWRecoveryFlags",00,22
F"BGMSFlags",00,22
F"PerformanceFlags",043C,22
Try to clone.
This works on F3 7200.14 Models?
Try coppy thist comands to F3 T?
PostPosted: March 24th, 2016, 3:32
Spildit wrote:
Instead of :
F009A,C1
F00E2,91
F00EC,B0
use :
F"BGMSFlags",00,22
on F3 T>
ok, i use
F"BGMSFlags",00,22
and next
/1
/N1
now im testing.
PostPosted: March 24th, 2016, 3:57
ok, ddrescue works again, but speed is very bad, about 190-200kb/s :/
There is any option to speed up this by comamnds in /T ?
This is screen from ubuntu and ddrescue
PostPosted: March 24th, 2016, 4:18
and this is F3 T/F
After this commands
ST2000DM001_F3_F.txt [44.23 KiB]
Downloaded 1657 times
PostPosted: March 24th, 2016, 5:16
"MindMergepk" already suggested above:
have you tried it ?
PostPosted: March 24th, 2016, 5:23
have you tried it ?
can i use -R in first scan?
Set this Bit to 1 can speed up?
Byte: 009A: Bit: 0 = 0 DISABLE_CORRECTION
PostPosted: March 24th, 2016, 5:25
why not ?
PostPosted: March 24th, 2016, 6:05
From F3 T F dump i notice the Correction is enabled
RWErrorRecovery Mode Page
              RWErrorRecovery Group
Byte:009A:       RWRecoveryFlags = 00
[b]Byte:009A:           Bit:0, DISABLE_CORRECTION = 0   [/b]
Byte:009A:           Bit:1, DISABLE_TRANSFER_ON_ERROR = 0
Byte:009A:           Bit:2, POST_ERROR = 0
Byte:009A:           Bit:3, ENABLE_EARLY_RECOVERY = 0
Byte:009A:           Bit:4, READ_CONTINUOUS = 0
Byte:009A:           Bit:5, TRANSFER_BLOCK = 0
Byte:009A:           Bit:6, READ_SPARING_ENABLED = 0
Byte:009A:           Bit:7, WRITE_SPARING_ENABLED =@0
To disable Coreection i must enter i f3T :
F009A,01
PostPosted: March 24th, 2016, 6:32
1. can you upload the terminal log ?
2. can you upload CTRL + x (last 32 commands) log ?
3. can you upload sys file 93 ?
Users browsing this forum: No registered users and 315 guests
