 Post subject: Stupid mistake I did with a rush and now I need to recovery
PostPosted: March 21st, 2016, 15:12
Hello all,
My reason to join the forum is because I need help with recovery my data of my external HDD.
The last days was terrible on my life and I will tell about it.
I did system recovery with ONEKEYRECOVERY to return to windows 8.1 OS because of personal reasons. Then, I downloaded Acronis 2015 (previous version was 2014) and I wanted to move my image of virtual box with read&write mode but I couldn't have so I saw a forum and they used DISKPART software and ran "Clean" command which I didn't understand initially. Then I got stress and I saw my device removed from my computer so I went to Disk Management with hope to do something and by mistake I didn't read and selected GPT.
Finally, I am trying Photorec software and it couldn't get me the full image of my TIB image backup of acronis.
With hope how can I recover my TIB image that is in my HDD?
PS: It's ADATA external HDD 1TB
Best Regards,
Mystic
 Post subject: Re: Stupid mistake I did with a rush and now I need to recov
PostPosted: March 22nd, 2016, 17:35
I can offer $ 25.00 btc if you help me to recover the file.
I lost my wallet password that is in the .tib file
The same file was in my HDD but I did system recovery and I am afraid I lost it.
Greetings,
Mystic
PostPosted: March 22nd, 2016, 18:21
I would start by cloning the drive, sector by sector, and then examine the clone with a disc editor. Can you show us the Partitions window in DMDE?
http://dmde.com
I'm assuming you typed "clean" rather than "clean all". AIUI, the latter command will write zeros to every sector.
Hopefully you didn't format your drive.
PostPosted: March 22nd, 2016, 18:48
<!-- m --><a class="postlink" href="http://dmde.com">http://dmde.com</a><!-- m -->
Hello fzabkar,
Thanks for the fast response.
Here screenshots of partitions window of DMDE program:
http://i.imgur.com/reLaORz.png
http://i.imgur.com/4Yan51Z.png
Can you suggest me a program to clone the drive, sector by sector in linux or windows?
Why should I do clone rather than image hdd?
Greetings,
Mystic
PostPosted: March 22nd, 2016, 20:08
You can use DMDE under windows or (personally I prefer) ddrescue under linux
PostPosted: March 22nd, 2016, 21:03
In DMDE, select Mode -> Hexadecimal/Text, then drag your mouse down the vertical scrollbar. Do you see data or just a bunch of zeros?
If you see data, then select Tools -> NTFS Search. Hopefully you will find a file system at around the 3GB point.
The difference between an image and a clone is one of semantics. I think of cloning as making a one-to-one copy of a physical drive, and I think of imaging, at least in your case, as copying the contents of a drive or a partition to an image file. This image file may be compressed. Some people use the two terms interchangeably, depending on the context.
PostPosted: March 24th, 2016, 10:56
Hello all,
after a desperate days I received days from a user, DRUG. DRUG thank you for the help, he assisted me with the data recovery. ( I sent him money for helped)
Now, I am doing data recovery to my files I really need and then I will format my external hard disk and put the files back. I also installed Dropbox and received 2 GB free and I will put things that they are important for me.
Best Regards,
Mystic
PostPosted: March 24th, 2016, 11:47
Mystic wrote:
Hello all,
Best Regards,
Mystic
Is a pleasure to help, if you are looking for more storage space for free you should consider MEGA.NZ (50GB free)
Users browsing this forum: Bing [Bot] and 242 guests
