 Post subject: WD7500KMVV-11BG7S0 ROM
PostPosted: April 8th, 2016, 7:23
I'm looking for a ROM for the following drive.
Model - WD7500KMVV-11BG7S0
Family - Shasta 3D
Thanks in advance :D
Web: https://www.day1data.de
 Post subject: Re: WD7500KMVV-11BG7S0 ROM
PostPosted: April 8th, 2016, 7:35
thay may help
http://files.hddguru.com/download/PC-30 ... asta%203D/
PostPosted: April 8th, 2016, 8:09
What FW ver.
PostPosted: April 12th, 2016, 8:13
Not sure sorry native ROM is missing.
PostPosted: April 12th, 2016, 8:14
hyuce wrote:
Thanks hyuce.
Tried all the ROM's from HDD Guru files. No success unfortunately.
PostPosted: April 13th, 2016, 13:02
Hello Day1data,
Have you found it? Can you access SA with another ROM+LDR ?
Best
F
PostPosted: April 13th, 2016, 13:22
If you use any ROM + matching LDR from the same family you can read tracks and then extract module 11 from those. From that module you can tell what ROM version the original was. Will save you a ton of time trying ones that will never work.
PostPosted: April 19th, 2016, 5:03
Thanks for the tip Data Medics.
Turned out there were head issues and the ROM was missing.
First the heads were swapped then the ROM was regenerated from SA.
Thanks to everyone for the replies.
