Spildit wrote:
What could have happened is that your cloning software is somehow flagging the sectors as good or somehow those sectors were added to the G-List by your software.
I cannot imagine that. My cloning tool has no implementation for such things..... at least as far as I know and understand the source-code.
Spildit wrote:
Do run MHDD/Victoria on the drive and scan it. It should find bad sectors at the start and across the drive.
This is the scan result with API mode
Interestingly it differs from the scan in PIO mode
Spildit wrote:
If so those bad sectors are still there and your software is just cloning the drive taking the data it can from the sectors and considering them as good ?
How could this be done without vendor specific commands? I don't think my cloning tool has built in VSCs.
I thought reading defective sectors with bad checksums could only be read by VSCs, or am I wrong?
Spildit wrote:
I'm sure that the drive have those 180 bad sectors. I didn't remap them to the G-List. Maybe your software managed to do so. Check S.M.A.R.T. and you should see the number of relocated sectors.
Smart Data (see screenshot in last post) seems to be similar to your screenshot.
Spildit wrote:
At any rate, do you have the totality of the data that you wanted intact ?
As far as I can see ALL the data from the important partition is there.
But I cannot confirm that until the owner tells me the same.
He hasn't picked up his drive till now
I think this should happen in the next days.
Please keep the image file till I get the OK from the owner.
