 Post subject: disk missing partions
PostPosted: May 8th, 2016, 7:03
Model no ST3500320AS
P/N 9bx154 - 305
Firmware SD1A
Site code SUZHSG
This disc shows in bios and in device manager
but not showing partitions in disk management
I need to recover data
 Post subject: Re: disk missing partions
PostPosted: May 8th, 2016, 14:00
It detects ID, FW part not and serialNo. it detects size =0 LBA=0
scan doesn't support
PostPosted: May 11th, 2016, 4:34
Thank you very much sir
If I did FW update data will be Lost?
Or I do using RS232 Adapter ? via Hyperterminal
PostPosted: May 11th, 2016, 7:09
Doing a firmware update will not repair the drive. A different part of the firmware component on the drive is damaged.
PostPosted: May 11th, 2016, 9:54
P/N 9bx154 - 305
Firmware SD1A
Site code SUZHSG
Hi ,
We Are Based In Chandigarh ,If You Like We Can Recover DATA For You .Analysis Charges Are USD 4/-
PostPosted: May 21st, 2016, 5:28
You will need the TTL adaptor and to follow the instructions on the link that i've provided.
Thank you Very much for your help
I got partitions successfully
PostPosted: May 28th, 2016, 2:07
Banned User
Very good
congratulation
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
Users browsing this forum: No registered users and 43 guests
