 Post subject: ST500LT012 - PCB NOT WORKING
PostPosted: May 24th, 2016, 3:47
Hello i have a SEAGETE MOMENTUS THIN ST500Lt012 with the pcb not working, i bought a donator pcb and i did a chip off the original rom on the new pcb but the hd don't run. Do you help me? there is an other solution?
tnx
 Post subject: Re: ST500LT012 - PCB NOT WORKING
PostPosted: May 24th, 2016, 9:35
I hope you didn't damage the the chip during the transfer
PostPosted: May 25th, 2016, 4:07
Spildit wrote:
You will need to check PCB with TTL, check drive output with TTL and check ROM as well.
Can i check with TTL the Original's pcb (not working) or donator's pcb (with your orginal's rom)?
tnx
PostPosted: August 21st, 2016, 5:43
ST500LT012 has 2 different PCB.
PCB number must be the same..
viewtopic.php?f=1&t=31674
Users browsing this forum: No registered users and 21 guests
