 Post subject: Which tools do you use to check scratches on the platters?
PostPosted: May 24th, 2016, 10:37
Hello everyone.. :D
I started a new data recovery lab
& I have a few questions
https://drive.google.com/folderview?id= ... sp=sharing
By the image, Will probably have scratches?
If there are scratches between the platters
(On the platters from the inside)
How can I check it without spend money a new donor drive?
(I can not separate the platters, they must be aligned with each other. Right?)
I have a stereo microscope and is standing in the area of the soldering, and I can not move it.
So I want to buy a another digital microscope to take pictures of
platters and heads in a clean room
Does someone know if it can do the job? Or is it junk?
http://www.ebay.com/itm/311236961973?_t ... EBIDX%3AIT
And what do you recommend?
Which tools do you use to check scratches on the pallets & make picture of the platters?
(Because it's like a mirror
There is a difficulty to make a picture)
Thanks.
 Post subject: Re: Which tools do you use to check scratches on the platter
PostPosted: May 24th, 2016, 20:16
I am no expert, but looks like a head problem... :mrgreen:
PostPosted: May 25th, 2016, 5:39
There is a problem with the read heads, it is clear..
The point is
That are likely to have a scratch on the surface as a result of the defective head
my question is
How do I check the inner side
Without spending money for the donor drive
Or to separate the platters
PostPosted: May 25th, 2016, 22:43
That must be a real headache :)
PostPosted: May 25th, 2016, 22:44
check the heads for dust
PostPosted: May 26th, 2016, 20:23
1) Strange sounds.
2) Dust on the filters and inside enclosure.
3) Dust on the heads (most useful indication).
4) Using signal/spectrum analyzer (good professional skills are required)
Users browsing this forum: No registered users and 61 guests
