 Post subject: ST250DM000 led BSY all time<==successfully recovery share
PostPosted: July 9th, 2016, 0:27
Hi all,
I want to share my hardly case with you.
Seagate ST250DM00-1BD141; Firmware: KC48
Led BSY all time. Can't get F3> with Ctr+Z
Rst 0x10M
MC Internal LPC Process
(P) SATA Reset
Then hang on.
After trying to do swap ROM, do short read channel 3-6 times with no luck.
Then turn power on - wait for 1-2 second then do short channel==>something change
Rst 0x10M
MC Internal LPC Progress
Spin Up
(DOS) Table Read Fail
DOS: MAGIC CONFIG NUMBER MISMATCH
Power off then on + wait for 5-6 minutes==>get led DRD and DSC :D
All data back to customer with 100% good quality.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
 Post subject: Re: ST250DM000 led BSY all time<==successfully recovery shar
PostPosted: July 9th, 2016, 5:25
this is long bsy problem
and if you need to apply solution after you login terminal you should clear DOS Table
/7m100
http://www.hpwlab.com
PostPosted: July 19th, 2016, 0:35
I agree. It must be long bsy problem. If power off and power on, the problem still exists. If you want to solve it completely, you can conduct m100 under level 7. I hope it can help.
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
 Post subject: Re: ST500DM000 led BSY all time
PostPosted: December 6th, 2018, 19:59
[quote="hddlab"]Hi all,
Seagate ST500DM02; fw kc66
Rst 0x10M
hdd stays bsy forever
Well could someone gimme a piece of advice which pins are needed to short to get finaly into F3> ?
PCB100535704 rev D
Tks in advance !
PostPosted: December 7th, 2018, 6:44
roger9 wrote:
hddlab wrote:
Hi all,
Rst 0x10M
PCB100535704 rev D
Tks in advance !
you must start a new thread, however these should be the points.
Data Recovery Pakistan
PostPosted: December 7th, 2018, 15:48
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
Users browsing this forum: No registered users and 427 guests
