 Post subject: When customers try to help . . .
PostPosted: July 13th, 2016, 15:58
Someone attempted to "repair" this drive. :shock:
http://www.datasaversllc.com
 Post subject: Re: When customers try to help . . .
PostPosted: July 13th, 2016, 16:28
Chip-off recovery, it is then.
PostPosted: July 13th, 2016, 20:52
Man, that's shameful. It's hard to tell whether chip-off is required; it might clean up nicely with a little flux and solder wick.
PostPosted: July 13th, 2016, 21:22
Unfortunately, there are SMT parts suspended in the globs of solder. From whence they came, I know not . . .
PostPosted: July 13th, 2016, 22:04
That was clear from the picture. Nevertheless, I would expect that once the abundance of solder is wicked up, the SMTs and their original positions might become obvious. Comparing the PCB to another in good condition would make it obvious.
That's just me speaking from ignorance, but necessity is the mother of invention when one doesn't do chip-off recoveries. Maybe that was the other tech's motto, too, now that I think of it. :)
PostPosted: July 14th, 2016, 1:19
I had the same idea. ISTM that it can't be too difficult for a competent tech to restore the status quo. It's certainly not a "chip-off" candidate at the moment.
Edit: BC? and BC4 appear to be the chip capacitors for the crystal (~10pF). There is probably a 1M resistor between the pins of the crystal.
             Y
             _
        |   |_|   |
        |   ___   |
        +--|_R_|--+
    BC ---       --- BC
       GND       GND
PostPosted: July 15th, 2016, 23:01
Unfortunately, I'm incompetent.
Oh yes it is.
PostPosted: July 15th, 2016, 23:19
Lol. I think Jon knows what he's talking about. Probably stuff you can't see from the picture.
PostPosted: July 16th, 2016, 1:21
Obviously the stick has suffered physical damage. This suggests that there was no electronic fault at the outset. Clearly the user (or DR shop?) tried to reattach the connector, perhaps by using wires. In fact I believe I can see the end of such a wire in the foreground. There are maybe 4 passive components which need to be repositioned. I have already outlined those that are associated with the crystal. Such a circuit is STANDARD practice for crystals. There is NO reason at the moment for a "chip-off" kneejerk.
PostPosted: July 16th, 2016, 2:23
Here are several standard crystal circuits taken from various manufacturers' reference schematics. Is this really too difficult?
PostPosted: July 18th, 2016, 11:35
Thank you for your help, fzabkar.
I appreciate it.
Jon
PostPosted: August 10th, 2016, 23:38
Well, I need to give fzabkar his props here.
The data was encrypted by Bitlocker, and efforts to reconstruct the data from the chip reads proved too difficult for the controller used.
So I reinstalled the two NAND memory chips, cleaned up the PCB by removing the solder blobs, and took some guesses about missing parts.
My reason for going with the chip read approach was to have a copy of the composite data, in case efforts to rebuild the drive ended up damaging the controller or the NAND memory.
We got 100% yield, including viruses. :-)
PostPosted: August 11th, 2016, 1:09
Thank you for your feedback.
PostPosted: August 11th, 2016, 11:17
Thanks for your help.
Users browsing this forum: Google [Bot] and 275 guests
