 Post subject: ST3500320AS with SD45 fw update problem
PostPosted: July 21st, 2016, 4:24
I have this drive with SD45 firmware (Google shows that this fw is usually paired with ST3500820AS) and it shows unknown cache size - a known issue with these drives having SD04 firmware, which the drive originally had according to the label. PCB no. is 100466725. I wanted to update to SD1A as recommended by Seagate, but having different (than expected by the update) firmware, the procedure fails. Is there a way to force the update or any other suggestions? Thanks in advance.
Those who know don’t talk. Those who talk don’t know.
 Post subject: Re: ST3500320AS with SD45 fw update problem
PostPosted: July 21st, 2016, 12:19
yes , you can force FW update
PM me
http://www.hpwlab.com
PostPosted: July 21st, 2016, 15:42
Here is the configuration file that is packaged with the update:
http://www.users.on.net/~fzabkar/MS-SD1A.TXT
This thread explains what you need to do:
viewtopic.php?f=7&t=25132
PostPosted: July 22nd, 2016, 13:41
Thanks, both of you. I read the other topic as suggested by Franc, but confused about how to do it. So I did a workaround: first updated to AD14 from floppy, then the SD1A (exe) went smooth. Funny, but Victoria still shows unknown cache size, so maybe it is a general Seagate or Victoria bug.
PostPosted: July 22nd, 2016, 15:59
The unknown cache size is not a bug but a limitation of the ATA standard.
Detecting Buffer or Cache Size in ATA Hard Disk Drives:
http://knowledge.seagate.com/articles/e ... uage=en-in
PostPosted: August 2nd, 2016, 17:30
For my SD45 ST3500820AS (difference is cache size) I was pointed to SD4A firmware.
My problem is the drive is in a USB enclosure (Medion HDD2Go) and after taking out the two endcap screws, can't figure out how to get anything else out - also has an ESATA connection.
PostPosted: August 9th, 2016, 17:38
i have never seen
are you sure? but sd15 common
your drive must be ST3500820AS. some firmware of this drive no need to upgrade.
Users browsing this forum: Majestic-12 [Bot] and 274 guests
