 Post subject: Unable to remove the heads from the HDD ! WD Scorpio Blue
PostPosted: August 19th, 2016, 13:12
Hello gurus!
could you explain me how to remove the heads from my WD Scorpio Blue 500 GB ? There is no screw to remove on both sides. I don't know how to proceed. I bought the same HDD to replace the heads.
Thank you !
 Post subject: Re: Unable to remove the heads from the HDD ! WD Scorpio Blu
PostPosted: August 19th, 2016, 18:05
Sorry! It was so easy. Just needed to take the heads to up! Problem solved. Data recovered!
PostPosted: August 19th, 2016, 19:47
Changing the heads is the easiest part of a recovery. Its making those heads work after a transplant and recovering the data with DR tools that you don't realize is the most difficult process. I would suggest stopping what your doing if the data is worth anything. Otherwise your wasting your time, our time, and your money.
PostPosted: August 19th, 2016, 20:07
PostPosted: August 19th, 2016, 20:35
I don't believe for a second it was recovered fzabkar.
Users browsing this forum: Google [Bot] and 57 guests
