 Post subject: Seagate ST3250312AS Barracuda 7200.12
PostPosted: August 25th, 2016, 10:00
I have disk like in the subject. Disk spin normally but isn't recognize in bios and windows.
From terminal I have:
Rst 0x08M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
                  vqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvq
SIM Error 1002vqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvq
SIM Error 1002vYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvY
SIM Error 1002
No HOST FIS-ReadyStatusFlags 2002A1A5
ASCII Diag mode
F3 T>/2
Any idea what I can do with this disk to repair it? Data is not important to me.
 Post subject: Re: Seagate ST3250312AS Barracuda 7200.12
PostPosted: August 25th, 2016, 13:01
RMA it. I wouldn't trust once failed drive :-/.
I'm not a pro, but from "F3 Serial Port Diagnostics" (don't know if it is same class of error codes):
DiagError - Diagnostic Error Codes
0x1002: Memory Miscompare Error
Anyway SIM error means errors with "files", which are used by firmware.
Before any actions, save all data from "/TF", "/TVfff" and "/TrXXX,3" (XXX = around 0-0x400, there are tutorials).
Support opensource code reverse engineering tool radare2.
