 Post subject: what does "RW subfile error 201F " mean?
PostPosted: August 31st, 2016, 3:40
ST31000528AS hdd have some bad sector. Suddenly it's gone...
it's visible on device manager
chkdsk says that MFT table corrupted....
is it possible to read data?
F3 T>m0,2,2,,,,,22
RW subfile error 201FMax Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level =
16, Max Certify Rewrite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
(P) SATA Reset
 Post subject: Re: what does "RW subfile error 201F " mean?
PostPosted: August 31st, 2016, 7:58
1.
2.
3.
then why in the world you're tampering with commands in terminal
Regardlees , chkdsk is a bad idea to use on any drive (you need to recover data)
PostPosted: August 31st, 2016, 13:18
F3 T>m0,2,2,,,,,22
F3 T>
Rst 0x20M
ExecuteSpinRequest
(P) SATA Reset
I hope this is your own drive - you have no idea about what you are doing right ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 1st, 2016, 5:12
this is my drive.. And not very important as i pay for any coin.
i 've been used hdd with bad sector...
i partited the disk for bad sector.
suddenly data lost.
at boot chkdsk says MFT corrupted.. i try to recover data via Active File with no success.
PostPosted: September 10th, 2016, 3:05
please explain meaning of "RW subfile error 201F".
Two of st31000528as have same problem now.
one is important.
it needs recover data.
PostPosted: September 10th, 2016, 15:46
one is important.
Module 28 has wrong CS.
PostPosted: September 10th, 2016, 17:58
one is important.
Sorry, module 2B, sysfile 28.
PostPosted: September 10th, 2016, 18:27
Read and Write F3 Arch Sys files with HyperTerminal :
http://www.hddoracle.com/viewtopic.php? ... 455&p=7475
F3 Arch Modules List :
http://www.hddoracle.com/viewtopic.php?f=6&t=831&p=3315
PostPosted: September 11th, 2016, 3:55
Thank you very much Martin and Fzabkar..i'll try it.
But Fzabkar
at the top Spildit thanks to me! :D
and i want to ask a question about pcb here..
viewtopic.php?f=1&t=34137
PostPosted: September 11th, 2016, 12:25
i wrote 28 subfile many time. but it's useless. additionally subfile 2043 error appears now.
i also rewrite 1c,1d,1e,28,35,133.
1b and 1f are unique.it gives
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0083, List Offset 00002F0A, List Index 0000035
B, File Error 000000D0
i already back it up.
F3 T>m0,6,3,,,,,22
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>m0,6,3,,,,,22
F3 T>w28
File Volume 3
File ID 028
File Copy Number 0
Start file transfer protocol in 60 seconds.
CCCCCCCCCC
File Descriptor FD34D028
File Size 00092800
Byte Offset 00000000
Bytes to write 00092800
F3 T>m0,6,3,,,,,22
PostPosted: September 11th, 2016, 13:45
I wasn't suggestiing that you write this file. AIUI, it is the translator which would make it unique.
PostPosted: September 13th, 2016, 3:53
i know it.
i rewrite original 1e and 1f.
DiagError 0000500E gone..
i took subfile 28 from another healthy ST31000528as
and sent subfile 28 to patient drive. it's useless.
it always seems "RW subfile error 201F"
PostPosted: September 13th, 2016, 8:42
Say what ???
SYSFILE 28 FROM ANOTHER DRIVE ?
WOW
PostPosted: September 15th, 2016, 4:44
Say what ???
WOW
is this unique too?
PostPosted: February 4th, 2017, 17:02
i get copy of "1" files patient and write it.
28,35,1b
drive and partitions is visible now. one part is not bad. but the others is very very slow.
data is important.
i think cloning takes 5 days.
273 mb of picture completed in 12 hours. disk conditions is bad.
why is that slow? any solution?
i need your help..
