 Post subject: [Donor Needed] Seagate ST3250318AS P\N: 9SL131-300
PostPosted: October 9th, 2016, 5:41
Hi guys!
I need Seagate donor drive with his excet parameters:
- ST3250318AS
- P\N: 9SL131-300, VERY IMPORTENT.
- 1 physical head: 00
Please, if you can, send me the ROM file to check compatibility, and price+express shipping to Israel.
Thanks!
 Post subject: Re: [Donor Needed] Seagate ST3250318AS P\N: 9SL131-300
PostPosted: October 9th, 2016, 7:24
Pharaoh
compatible
ST3250312AS
ST3500410AS
ST3500413AS
ST3320418AS
ST250DM000
ST500DM002
PostPosted: October 9th, 2016, 7:53
Hi Tomset,
In most cases it can be compatible.
but in this case the head map is not standard.
You can see it here in the attached ROM file
Thanks.
PostPosted: October 9th, 2016, 15:55
more heads should not be a problem.
correct me if am wrong here please.
Data Recovery Pakistan
PostPosted: October 13th, 2016, 7:15
Because the platter position on this drive model, there is no physical way to enter 2 heads.
PostPosted: December 6th, 2016, 9:17
Still Relevant!
Users browsing this forum: Google [Bot] and 47 guests
