 Post subject: Donor PCB for WD10TMVV?
PostPosted: October 19th, 2016, 21:06
Looking to do a PCB swap for WD10TMVV-11BG7S0. I believe if swapping for integrated USB PCB I'd have to swap both u12 and u14? Is a SATA donor possible for this model?
USB port on original PCB is damaged. Original PCB board number is 2060-401675-004 REV P1, white label is 2061-701678-301. U12 chip is type 1 as pictured in this post http://www.hddzone.com/blog/western-dig ... 2-5-pcb-2/
 Post subject: Re: Donor PCB for WD10TMVV?
PostPosted: October 20th, 2016, 1:12
Sata donor: 701672
http://www.rescue-it.se
PostPosted: October 21st, 2016, 8:04
As mr-spokk said, 2060-771672-004 is the SATA PCB you need. If you're swapping to another matching USB PCB then yes, move U14 as well.
Data Recovery Cape Town
Users browsing this forum: No registered users and 50 guests
