 Post subject: The Bearded Lady
PostPosted: October 25th, 2016, 10:37
Close-up of head contamination from a 3 TB Toshiba (Hitachi)
http://www.datasaversllc.com
 Post subject: Re: The Bearded Lady
PostPosted: October 25th, 2016, 10:42
So, you plan to clean and re-use the existing heads or replace them? Or does the media look like a lost cause?
PostPosted: October 25th, 2016, 11:48
Looks bad. I guess it is better to go with donnor heads. One question, where did that contamination come from? Has the hdd been opened before o it came from a head crash?
best,
F
PostPosted: October 25th, 2016, 12:38
The fuzz is the coating from the platter. Have seen before, most recently last week on a WD Passport drive. Head is mangled just enough to cause very mild scratching.
PostPosted: October 25th, 2016, 15:44
Also seen that a lot on Seagate 7200.10 drives.
PostPosted: October 26th, 2016, 16:01
Normally, I'd replace these. The platter surface isn't visible.
PostPosted: October 26th, 2016, 16:03
best,
F
As noted in the thread by labtech, the contamination results from the head scraping the media.
The drive had been opened by a non-professional before we received it, but I think that is unrelated to the cause of the contamination shown.
PostPosted: October 27th, 2016, 9:21
jono-ats wrote:
best,
F
Thanks for your answer and for sharing.
Best!
F
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 78 guests
