 Post subject: WD Elements 2TB issue
PostPosted: October 26th, 2016, 8:27
I was copying some files to my 2Tbytes WD Elements and suddenly the disk hanged and stopped working. I left it there over 30 minutes but nothing happened.
Disconnected it and try to reconnect again. The disk now cannot be initialized, and is seen by device manager (WD Elements 10B8 USB Device) but not by windows (running win10 64 bits).
Also cansee it in Disk Management as Disk 2 Unknown, ask me to initialize it choosing a partition between MBR and GPT but fails because size of disk shows as 0.
Lifeguard diagnostics see serial number, capacity 0Mb, Smart status not available and pass both quick and extended test immediately (of course, being 0Mb....).
Test Option: QUICK TEST
Model Number: WD Elements 10B8
Unit Serial Number: shows correctly
Firmware Number: 1012
Capacity: 0.00 GB
SMART Status: Not Available
Test Result: PASS
Test Time: 20:25:24, October 26, 2016
Most of the data on the HD I could get again easy, but I had some photos of the kids there where I have no backup....
Any clue?
Thank you!
 Post subject: Re: WD Elements 2TB issue
PostPosted: October 26th, 2016, 15:17
Is this a 2.5" HDD or 3.5" HDD?
PostPosted: October 26th, 2016, 23:43
It is a 2.5"HDD. WD Elements SE. 2 Terabytes. USB 3.
PostPosted: October 27th, 2016, 3:25
Spildit wrote:
Full model of the drive ?
WD Elements SE 2 Terabytes USB 3.
PostPosted: October 27th, 2016, 3:26
WD Elements SE 2 Terabytes 2.5"HDD USB 3 external drive
PostPosted: October 27th, 2016, 16:29
The 2.5" models usually integrate the USB electronics on the HDD PCB. It appears that your software can detect the USB-SATA bridge but not the HDD behind the bridge. Normally you would convert the USB PCB to SATA, and then try to read the drive's firmware modules, or perhaps execute the "slow fix". DIY may be possible, depending on your resources and level of skill.
PostPosted: October 27th, 2016, 16:54
Capacity: 0.00 GB
Test Result: PASS
Any clue?
Thank you!
Do you hear any unusual sound from inside of the drive? Any rhytmical sound?
Users browsing this forum: Austinblake22, Google [Bot] and 50 guests
