 Post subject: PNY 64GB Flash Drive Issues
PostPosted: November 2nd, 2016, 12:35
I have a PNY 3.0 USB flash drive with unusual symptoms, can anyone help me diagnose. One time you connect the drive is shows up as a PNY USB 3.0 FD 1100 with the LED flashing constantly (usual fast pulse for a PNY) but no sector access. Next time its connected it shows as SMI USB MEMORY BAR 1000 (which I presume is the controller signature as its a SM3267L) with a slow pulse of the LED, again no sector access. Next time it does not come live at all. The controller does not get hot. Rewired the connector as there was some damage to the anchor points from a previous bend (red herring I think). Quick test of components found a bad resistor and replaced but no difference. Client said it just stopped working rather than sustained physical damage.
 Post subject: Re: PNY 64GB Flash Drive Issues
PostPosted: November 2nd, 2016, 13:54
Reflow the controller. Maybe there is some crack on solder connection. It sometimes happen. If not help chip-off recovery should be success.
PostPosted: November 2nd, 2016, 14:57
Thanks for the advice as always. Looks like a chip off is needed (just don't tell Fzabkar :wink: )
PostPosted: November 2nd, 2016, 15:22
PostPosted: November 6th, 2016, 2:57
Any luck? I always have interest in PNY..
Recover My Flash Drive
PostPosted: November 6th, 2016, 9:00
Still waiting for client approval. I will let you know.
PostPosted: November 16th, 2016, 3:31
i hope you may find a way of approval by client...
also let me know if you've done...
Cheers!
#Brain
Human Lover!
Manager @ Custom USB Canada
Users browsing this forum: Bing [Bot] and 136 guests
