 Post subject: Samsung HD103SI restarting computer
PostPosted: November 6th, 2016, 11:18
This time I have disk Samsung HD103SI. After connecting power from computer power supplier to disk computer is restaring. Also connecting only PCB still computer restaring.
At the begging I check diodes, so I replace one of them. But after that still is the same problem.
Could you help me with diagnose this PCB? I attached photo my PCB.
Marcin
 Post subject: Re: Samsung HD103SI restarting computer
PostPosted: November 6th, 2016, 17:09
@lasek, "restarting" suggests that the computer is in some kind of boot loop. A shorted TVS diode would cause the PSU to shut down. Could you clarify what you mean?
PostPosted: November 7th, 2016, 8:45
OK. I have working computer with windows. So after when I connecting power to disk from power supplier this computer then computer shut down in the moment. This problem only with this one disk.
PostPosted: November 7th, 2016, 16:05
Then you need to follow Spildit's advice.
http://www.users.on.net/~fzabkar/HDD/HD103SJ_TVS_2.jpg
PostPosted: November 8th, 2016, 16:42
Once again thank you for your help. I replaced both diodes and now pcb and disk works.
Marcin
Users browsing this forum: No registered users and 51 guests
