 Post subject: G-lis to P-lis error
PostPosted: November 17th, 2016, 23:36
HI FRIENDS, IS THERE THAT CAN HELP ME WITH THIS PROBLEM ..
how to improve G-lis to P-lis error ..
 Post subject: Re: G-lis to P-lis error
PostPosted: November 19th, 2016, 10:25
G list to P-list never worked when i tried in MRT Hitachi utility.
MRT has many bugs, this is one of those.
My firmware database:
PostPosted: November 19th, 2016, 10:50
wrt0,wrt1.
do not write two heads ?
PostPosted: November 21st, 2016, 5:45
Spildit wrote:
Moltke wrote:
wrt0,wrt1.
I think that MRT will not read those modules properly and will state error even on Known GOOD DRIVES ...
:D :D :D
You think right, MRT returns always error when you try to read those mod, even if the drive is new and perfectly working.
PostPosted: November 21st, 2016, 17:18
Drive is using (checking writing) only first sector of those modules. So first sector should be readable. If not - there is problem with heads - just writing or reading or both in same time. (Or there is bad sector.)
PostPosted: November 21st, 2016, 17:28
read carefully. I am not talking about programs and how they work with modules. If stupid program trying to read module where only first sector formatted - I don't care. You can use my info or not - it's up to you.
PostPosted: November 24th, 2016, 2:40
so what should i do .. do I need to buy another seftware ..?
PostPosted: November 24th, 2016, 9:03
I bought few days ago Sediv for Hitachi, but i still haven't tried it yet, as i know it should work properly when working on hitachi fw. Sediv is very good software for fw repair, the only limitation of it is that it doesn't have data extractor for data cloning and is strongly restricted to computer hardware and software configuration, this means that if you change your computer configuration after you have activated sediv (i mean since you get sediv license) then it will stop working on your computer.
The only way to make it work again is by returning to previous pc configuration, or by activating it again.
PostPosted: November 25th, 2016, 3:14
Application WHAT Should I buy,, so that I can be to fix it ..?
PostPosted: December 3rd, 2016, 10:23
I have at the moment a new HGST HTS545050A7E680 drive FW: GR20A3J0 which is not supported yet by Sediv (i can't access into SA), but also MRT is not able to access into it by utility.
When i will get another hitachi drive which is supported by sediv, i will do some G to P test
PostPosted: December 4th, 2016, 13:17
Banned User
You should contact the support team MRT to better
PostPosted: January 15th, 2017, 6:38
Hi Michael
You can move G to P of Hitachi Drive, Even if you not have SA access.
Select option ARM, then press ok to enter into Utility, then goto translator> G to P
thats all.
its works by VSC commands
Users browsing this forum: Google [Bot] and 222 guests
