 Post subject: Seagate ST3250318AS with LED:000000CD error ?
PostPosted: December 6th, 2016, 6:54
I have Seagate ST3250318AS it stuck on BSY
the terminal keeps giving me this over and over:
LED:000000CD FAddr:00258A17
I replaced head and still the same issue ??
HDD label attached
 Post subject: Re: Seagate ST3250318AS with LED:000000CD error ?
PostPosted: December 6th, 2016, 7:28
May be eeprom fail
pls check eeprom with other same working board
I have same problem
PostPosted: December 6th, 2016, 11:23
prasadsv wrote:
May be eeprom fail
I have same problem
Now i got the SN and model but the size is empty
when i do anything the drive freeze with BSY DRD DSC
PostPosted: December 6th, 2016, 13:12
Have you tried F3 commands in terminal?
http://www.hddoracle.com/viewtopic.php?f=83&t=38 try this with TTL adptor
PostPosted: December 6th, 2016, 14:47
This is a great way to brick the drive and make it unrecoverable. Seriously, read the GIANT RED TEXT THAT SAYS:
DON'T DO IT ON NEWER DRIVES, LIKE 7200.12 OR YOU WILL END UP HAVING FURTHER COMPLICATIONS DUE TO NRG LIST / TRANSLATOR !!!!!
PostPosted: December 6th, 2016, 15:21
LostDataSa wrote:
prasadsv wrote:
May be eeprom fail
I have same problem
What tools do you have ? Do you have PC-3000, MRT Pro, SD Seagate doctor, HRT 5.0 / UDMA or SeDiv ?
Do you have at least some "chinese" firmware tools that you can use to backup sysfile/CPs on your drive ?
Can you post a FULL terminal log ?
Did you disable relocation and media scaning with Congen or PC-3000 editing sysfile 93 ?
Did you check if the drive have NRG-List entries with V40 ?
PostPosted: December 6th, 2016, 16:59
Of course this might as well be as simple as S.M.A.R.T. log pointers or other S.M.A.R.T. related damage....
Now you replaced heads and added up more problems ....
If drive were to be in it's original condition you could try to gain terminal access, backup SA and clear S.M.A.R.T.....
PostPosted: December 6th, 2016, 18:25
Why did you decide to swap heads or even open the drive on a 7200.12 stuck on BSY with led CD ? Wouldn't it be better to assume that most likely it would be firmware related problem and not heads ?
PostPosted: December 7th, 2016, 5:43
head was damaged but after replaced head this happed
it clicks several times then comes to ready
after running utilities i can read model and SN good but firmware showing CC44 which is the firmware of the donor drive and the size is MB ()
when i try to do anything it stuck on BSY DRD DSC.
I have terminal access while it is ready
i am using pc3k
here is log:
Family ID by HDD ID: 3F
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST3250318AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Drive not ready
Terminal : error detecting HDD terminal baud rate
Terminal:
Rst 0x08M
ASCII Diag mode
F3 T>
Rst 0x08M
and this is log when I try to clear SMART:
Executing user command.................. : Clear SMART
ASCII Diag mode
F3 T>/1
F3 1>N1
HighPowerMode
Terminal : reply timeout error
Executing user command.................. : Show Alt-List
LED:000000CC FAddr:002851C7
PostPosted: December 7th, 2016, 15:21
:shock: :shock: :shock:
Are you using the donor ROM or something like that ? How did the donor firmware ended up on the patient drive ?
