 Post subject: ST500LM000-1EJ162
PostPosted: January 16th, 2017, 19:44
Hi there,
I did some research on the ST500LM000 on the google and there in forum also and Im getting an opinion that it is not so good drive but let me ask you a question:
I have one ST500LM000-1EJ162 with stuck heads on the platter, but accidentaly I broke the head on its recovery.
So I did a little research in my stock and found the same working drive with the same model and the same second and third number in seriál number, even the datecode is the same. On the head, there is a part number that is the same for patient and donor. So I did the head swap.
Now the disk is visible to the BIOS, but Im unable to read anything from it.
Maybe it should be useful to show the console log:
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
Request spin / disc table recovery
ASCII Diag mode
F3 T>
RECOV Servo Op=0100 Resp=0005
TCC:0022
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0155 Resp=0005
EDAC Value = 0000F018E59ED798
RECOV Servo Op=0065 Resp=0005
Strt Cln1
ABORT!
OpCode = 00000000
SenseCode = 03310000
ReadyStatusFlags = 0002A1A1
ABORT!
OpCode = 00000000
Am I missing something or the platters are also gone?
Best regards,
Jan
Users browsing this forum: ccc, Google [Bot] and 214 guests
