 Post subject: Toshiba 1.8" pinout
PostPosted: March 10th, 2017, 8:51
Can someone help me identify pin 1 on mk1003gal? I bought an adapter and having trouble finding the correct way of attaching the drive to it.
TIA.
Those who know don’t talk. Those who talk don’t know.
 Post subject: Re: Toshiba 1.8" pinout
PostPosted: March 10th, 2017, 9:15
https://yadi.sk/i/ieEXH7VA3FSzNn
PostPosted: March 10th, 2017, 10:30
Thank you / Спасибочки :wink:
PostPosted: March 10th, 2017, 13:59
Without power applied, plug the adapter into the HDD. Using a multimeter, test for continuity between a ground point on the adapter and a ground point on the HDD PCB (eg a screw hole). Invert the adapter and repeat the test.
For additional confidence, repeat the test for the +3.3V test points. The +3.3V pins on the HDD side should be identifiable by their thicker power traces.
MK1003GAL (HDD1262) 1.8-inch Hard Disk Drive User Manual:
http://pdfstream.manualsonline.com/9/99dc24ed-06f2-4319-b858-a98b7b2948f0.pdf
PostPosted: March 11th, 2017, 7:04
Thank you, Franc, I could figure out based on Tomset's answer.
Now the only thing I need is some VSC's to clear SMART and G-list. :)
PostPosted: March 11th, 2017, 14:23
You can read the CPs using appropriate commands in MHDD or other ATA terminal software such as HDDSuperTool:
http://www.hddoracle.com/viewtopic.php?t=1254&p=11784
Users browsing this forum: Google [Bot] and 70 guests
cron
