 Post subject: Long Delay Detect Issue in Seagate
PostPosted: May 6th, 2017, 6:48
Hello Guys,
I have Seagate Barcuda 1TB . this hdd is does not detect on PC so i connected to MRT and saw its busy and not detected but after waiting for 3 min it become detectable in this situation i just want to know is there ant solution to repair the hard drive for normal work? i checked it with Logic Scan and it was very healthy on that so i want to know if there is any solution for repair hdd.
 Post subject: Re: Long Delay Detect Issue in Seagate
PostPosted: July 23rd, 2018, 8:32
check the modules, module 35 is corrupted, re write the module from a donor.
PostPosted: July 23rd, 2018, 10:08
@OP, just ignore this.
You need to modify system file 93 to disable all the SMP options such as bad sector reallocation and media cache. In MRT I believe it's called, "Edit HDD ID" to get to that function (though I've never found it to work well in MRT).
