 Post subject: TOSHIBA MQ02ABF050H can't access all LBA
PostPosted: July 4th, 2017, 0:55
Hello everyone,
I have TOSHIBA MQ02ABF050H it can read ID but cannot access all sector.
Could someone facing this problem and advice the solutions?
Kindly advise
Best regards,
Kimphonix
 Post subject: Re: TOSHIBA MQ02ABF050H can't access all LBA
PostPosted: July 4th, 2017, 4:42
It is SSHD, with high probability you have problem with NAND. If it is possible, please, provide terminal (diagnostic port, TTL) report.
PostPosted: July 4th, 2017, 5:17
Hello Martin,
Thank you for your reply. The initial message in utility looking good can read ID as follow
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 244 672
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MQ02ABF050
Microcode............................... : HDFD2C0G
Defects in G-List....................... : 0
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FE,FF
And the message on terminal has just little as follow
P90 FATAL
P90 FATAL
HF
Best regards,
Kimphonix
Users browsing this forum: No registered users and 24 guests
