 Post subject: Samsung HD103SI/Y 1GB dont spin.
PostPosted: August 31st, 2017, 11:10
Hi :) in the PCB of this disk i allredy see the diode problem, i take it off but still the hdd is dead, does a simple pcb swap works in this drive? thanks
 Post subject: Re: Samsung HD103SI/Y 1GB dont spin.
PostPosted: August 31st, 2017, 11:31
Oh i found now the head was stuck, but still no spin.
PostPosted: August 31st, 2017, 12:40
The head stuck on the disk surface?
PostPosted: August 31st, 2017, 13:07
Yes i think
PostPosted: August 31st, 2017, 17:09
NelsonSilva wrote:
Yes i think
Do you think, or you are sure? how did you check?
I guess there is a fuse on the pcb that blows off when the tvs gets shorted...
PostPosted: August 31st, 2017, 17:59
Was it the 12V TVS diode that was shorted and if so, did you check the zero-ohm link?
Users browsing this forum: No registered users and 29 guests
