 Post subject: Two hard disks on NAS burned high capacity TB 1 or 2 Terabyt
PostPosted: September 22nd, 2017, 16:30
Hi!
A friend of mine told me that two Hard Disk burns.
These hard disks have burned.
Inside there are very important data, there is professional software that can recover data on these two hard drives.
How can I do ?
I would like to try it in free if I can, if I can not prefer to consult some Italian assistance.
Thanks for answering.
 Post subject: Re: Two hard disks on NAS burned high capacity TB 1 or 2 Ter
PostPosted: September 22nd, 2017, 16:36
What makes you think that a "burnt" HDD is a "soft" problem? Or was something lost in the translation?
PostPosted: September 22nd, 2017, 16:45
Hi!
Thanks for the answer
I used the translator I'm Italian.
My friend has the NAS inside has two hard drives I do not remember if they were 1TB or 2TB.
He told me that these two hard drives have burned but I do not know what they were causing.
I said there is a software that can recover these burned hard drives.
there are very important data.
If I do not and tell him to consult a specialist technician.
PostPosted: September 22nd, 2017, 16:55
"Burned" implies that there is physical damage, specifically damage due to fire. If you want help, then you need to supply much more information.
If you are looking for a point-and-click tool ("fix-everything-that-is-wrong-with-my unspecified-hard-drive.exe"), then you will be sadly disappointed.
PostPosted: September 22nd, 2017, 17:07
ok thanks
When I go back to my friend's house I inform you better
PostPosted: September 22nd, 2017, 18:25
If the data is very important, you should avoid doing things that can compromise or make the situation works.
Ideally, post here the model of the disks, and also pictures of them, both sides, before trying to do something, and also before connecting them to a computer.
Also, post the brand and model of the NAS.
Users browsing this forum: Google [Bot], mima85 and 67 guests
