 Post subject: WD Platter Replacement (Alignment Issue)
PostPosted: July 9th, 2018, 11:04
Hi
Do you have good success rate about platter replacement of WD 3.5"?
Considering Alignment issue? (motor balance issue)?
Its a 1 platter HDD?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD Platter Replacement (Alignment Issue)
PostPosted: July 9th, 2018, 11:54
shahij wrote:
Hi
Well,
Are you having any issue in any case ,If yes i will assist you privately tomorrow if you indeed have a issue ,1 Platter is not a issue at all ,
PostPosted: July 9th, 2018, 13:09
Hi Amar,
Did you make any successful transplant of platter in WD 3.5" HDD? 1 PLATTER?
If so, what was the model you dealt?
It would be nice to see your feedback.
__________
THANK YOU
SHAHI
PostPosted: July 9th, 2018, 13:23
It shouldn't be a problem on any 1tb 1 platter WD.
PostPosted: July 9th, 2018, 16:20
Thank you
__________
THANK YOU
SHAHI
Users browsing this forum: Zack Lai and 73 guests
