Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: PCIe SSD to SATA Question
PostPosted: October 8th, 2018, 9:17
mr_spokk wrote:
mr_spokk wrote:
This might is what you look for:
Then what?
http://www.ssdformfactor.org/docs/SSD_Form_Factor_Version1_00.pdf
No, but the OP was also looking for something that were outside the box for better cooling opportunities.
But you can continue with hacksaw and cutting :wink:
Your "solution" is useless on its own. At the very least, it requires additional hardware.
Moreover, if the heat affected component is on the underside of the PCB, then you will derive little, if any, benefit from the adapter unless you cut away the obstruction. In any case, you need to first investigate the cause of the heating, which necessitates access to the PCB with a multimeter.
Do you understand now?
PostPosted: October 8th, 2018, 11:19
Yes, but sometimes you need to buy new hardware.
There is around 8mm of space underneath...+ maybe 2-3mm more if it's not tightened...so there is some space for cooling without cutting.
And of course if you find the shorting problem that cause the heat, then it's of course better to swap that component.
Yes I understand, you have a issue....so I'm out.
http://www.rescue-it.se
PostPosted: October 8th, 2018, 11:52
Thanks you everyone for all the feedback. All very informative. I will do some testing/experimenting and get back to you all.
PostPosted: October 15th, 2018, 17:13
JMicron JMS583 USB 3.1 Gen 2 to PCIe Gen3x2 Bridge Controller:
http://www.jmicron.com/PDF/brief/jms583.pdf
The JMS583 is a USB 3.1 Gen 2 to PCIe Gen3 x 2 bridge controller between USB host and PCIe storage device.
Aluminum NVMe PCIE USB3.1 HDD Enclosure M.2 to USB SSD Hard Disk Drive Case Type C 3.1 M KEY Connector HDD Box for Desktop PC (US$40):
https://www.aliexpress.com/item/Aluminum-NVMe-PCIE-USB3-1-HDD-Enclosure-M-2-to-USB-SSD-Hard-Disk-Drive-Case/32884307172.html
PostPosted: October 15th, 2018, 17:48
Nice find Frank
https://www.mjm.co.uk/
PostPosted: October 15th, 2018, 17:56
scratchy wrote:
Nice find Frank
+1
PostPosted: October 15th, 2018, 20:37
Here's the English language page for apparently similar items at a wide range of prices.
PostPosted: October 16th, 2018, 3:02
I have this one...
https://www.megamac.com/collections/env ... o-ngff-ssd
Users browsing this forum: No registered users and 151 guests
