 Post subject: If the alignment of the platters lost...¿ Game Over ?
PostPosted: November 24th, 2018, 8:30
I have read in many places that if the alignment of the plates is lost (for example when removing them to clean, and then reassemble them) the information is irretrievable. Is there no way to realign it as it was in the factory?
I have read everything, people who say it is impossible, and people who say that it is possible to recover the alignment.
What's the true about all this ?
 Post subject: Re: If the alignment of the platters lost...¿ Game Over ?
PostPosted: November 24th, 2018, 8:57
The truth is that some makes/models are extremely sensitive to platter alignment whilst others aren't.
For models that are sensitive to platter alignment, when it's lost, it's game over, IMHO.
PostPosted: November 24th, 2018, 8:59
+1
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 24th, 2018, 12:32
And how do the recover data companies when they have to take out the platters to clean ?. If the model is very sensitive to alignment they not try?
PostPosted: November 24th, 2018, 13:33
They keep it a secret so that competitors don't do it for less.
PostPosted: November 24th, 2018, 19:22
https://www.youtube.com/watch?v=J9P4UadRdNA
PostPosted: November 24th, 2018, 20:44
Maybe I'm a perfectionist, but this was painful to watch. It also doesn't answer how to realign platters that are moved individually, as was asked.
PostPosted: November 24th, 2018, 21:16
...you found a video showing a widely-known method of keeping platters aligned while moving them to another base.
It takes another level of expertise to be able to remove platters from a multiple-platter drive INDIVIDUALLY, clean them, and then reproduce original platter alignment and eccentricity.
In response to OP's question, if platter alignment is completely lost, the original alignment is as likely to be reproduced as getting a Seagate F3 to initialize with a different PCB/ROM.
With the right tools however, many drives can be made to initialize off the first platter then platters can be imaged individually.
...not with all drives though as previously stated. With Seagates in the Crawford family if original platter alignment and eccentricity is lost, you may be able to image the bottom platter (with the right tools) but beyond that you're hosed.
PostPosted: November 25th, 2018, 8:02
Why?
PostPosted: November 30th, 2018, 10:13
driverDave2 wrote:
Why?
I have a very strict rule here; never put your hands over the platters unless absolutely necessary. Even with gloves on, touching the platters can cause issues. So, unless you need to be working with the spindle, there is no reason to move your hands over the platters.
Spend $100 on a hard drive stand from Apex Tool Lab or a fancier version from HDD Surgery for a little bit more.
PostPosted: November 30th, 2018, 12:59
Well,
This Guys LAB Is a Pile Of Dust ,He Might Be Good In Repair Of MACS He Is Absolutely Nowhere Close To a DR Tech .Did i Hear Someone Say We Can Work With Primary Platter And Then Others Will Be a Hassel In F3 Seagate :D ,Not With Me Buddies While Platter Cleaning ,Few Cases Are Still There With Me In The Main LAB .I Am Slowly Feeling Little Better But Still Not Too Much In Office But i Miss My Community And Youtube Channel :(
PostPosted: November 30th, 2018, 18:38
I use the video method to change the plates from one record to another, but with small differences.
What scares me is giving heat to a disc because in my opinion it can produce deformations in the dishes, just as with the temperature the magnetic fields can deteriorate.
The papers I stick to the adhesive tape before putting them on the plates.
PostPosted: December 3rd, 2018, 13:28
I have an experience with Hitachi hdd. Totaly lost platter alignment . It was work .I never tired another one. But I will try . lol.
Sexy Womans from your town
Users browsing this forum: No registered users and 309 guests
