 Post subject: Does a WD1200JS needs head alignment?
PostPosted: November 27th, 2018, 5:04
Hello, I want to verify apart from the DCM match for the donor drive, do i have, after the head swap, to do head alignment to the patient? also is there a way to change parameters in PC3000 to fix this issue?
the model is WD1200JS-00MHB0
Thank you in advance
 Post subject: Re: Does a WD1200JS needs head alignment?
PostPosted: November 27th, 2018, 9:01
No, it does not.
HddSurgery - Professional Data Recovery Tools
PostPosted: November 27th, 2018, 12:40
thank you for the reply. well i thought after the post to take another drive to check it out and i saw that it didn't need head alignment.
Users browsing this forum: Google [Bot] and 278 guests
