 Post subject: WD HGST WD10SMZW WD10SDZW HTS541010B7E610 800066 unlock
PostPosted: January 10th, 2019, 6:58
please note you still need firmware tools. won't work with desktop only.
PCB to unlock firmware access for the following models :
HGST HTS541010B7E610 PCB 2060-800066
WD WD10SMZW-11Y0TS0 PCB 2060-800069
WD WD10SDZW-11UMGS0 PCB 2060-800069
USD $300 include shipping to most country.
This is one data recovery PCB specially designed to recover lost data from new WD hard drives with PCB number 2060-800066 (SATA) and 2060-800069 (USB). These drives have main chip lock and it’s not possible to read or write the ROM and access to SA by any firmware repair tools.
Now it is possible to recover these drives!
Whether it is 2060-800066 sata PCB or 2060-800069 USB PCB, users can use this data recovery PCB for data recovery purpose.
To use this data recovery PCB, users just need to solder the patient ROM chip off and solder the patient ROM chip on to the donor data recovery PCB and then install the data recovery PCB.
After above PCB and ROM swap, users can access to ROM and SA and repair the firmware corruptions.
Users can use this same data recovery PCB to fix multiple 2060-800066 or 2060-800069 data recovery cases, it depends on users’ chip soldering skills.
This unit is sold "AS IS" for parts or repair, and without any warranty.
will only sign your userID on the PCB and record a video of it accessing the firmware via PC3000.
 Post subject: Re: WD HGST WD10SMZW WD10SDZW HTS541010B7E610 800066 unlock
PostPosted: January 10th, 2019, 10:26
So you managed to find the unnecessary C.?
Donordrives was 380$ then after less than a month
DFL 350$ then now
You 300$
few days more probably then.... who knows
PostPosted: January 10th, 2019, 15:44
Cool ! :D
PostPosted: January 30th, 2019, 4:45
Has anyone actually bought one of these, or similar from another vendor?
If so, I’d be very interested in feedback if you’d like to PM me?
Cheers!,
PostPosted: February 2nd, 2019, 10:42
Does This Actually Work ,I Am Also Sure They Have Done Nothing Just Managed To Find Some Already Unlocked Once ,Also I Have a Friend Who Was Quoted USD 1200 For Such A Similiar PCB Why Two Rates I Have No Clue .This Guy Seems To Be DFL Guys ? .Might Be We Can Dig Our 1TB Stocks To Find Some Unlocked One :mrgreen:
PostPosted: April 9th, 2019, 9:59
As a documentation that this thing works. somehow i can't get the head map in data recoverer.
PostPosted: July 15th, 2019, 11:58
I have WD10SMZW-11Y0TS0 with 2060-800069-001 rev P1.
Can I change PCD to SATA?
How much your pcb?
PostPosted: August 1st, 2019, 3:35
DFL 350$ then now
You 300$
Update,,,
my prev. comments was in Jan.
Now the wholesale price became:
100$ Palmer
200$ Charger
someone once said: "When there is WAR, Invest in real estate"
probably right..
