Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 4 TB backup plus not being detected
PostPosted: October 25th, 2017, 18:34
Letting me know for how to get terminal log plz.
Coz after I unused with sata adapter, i used directly HDD with Sata to Mother board slot 2. When i make like this window is pending too long to boost n can't see anymore to teminal log.
Thx
PostPosted: May 27th, 2018, 3:50
jermy wrote:
ahub1988 wrote:
waiting for a response
then this is what you supposed to do
find a PC, connect the HDD to it and answer the question
1. what happens if you connect it directly to SATA
2. Does it make any bad sounds
3. (1 of my own) show the terminal log
is it so hard ?
Sorry for such delay,
So i managed to connect my HDD directly to SATA port in desktop computer
It doesn't detect in windows 10
1 have 4 hard drives connected
Detects 3 devices
No bad sounds, but spins
my question is how to get a detailed terminal log
PostPosted: June 9th, 2018, 6:45
Spildit wrote:
You need to buy something like this :
http://www.hddoracle.com/viewtopic.php?f=46&t=192
And connect to the drive like this :
http://www.hddoracle.com/viewtopic.php?f=6&t=193
Power UP the drive and DO NOT issue any command, just copy the terminal log to here.
I got it and connected now how to get log??
PostPosted: July 4th, 2018, 3:41
I am unable to get terminal log by the guide, can you please tell me how to get in simple terms, Thanks.
PostPosted: April 21st, 2019, 4:52
I tried terminal log
Nothing appears, on attaching sata cable in desktop, or original pcb socket cable.
I noticed in when two jumper cables shorted with each other device accidently it had changed name to disk drive in device manager
PostPosted: April 22nd, 2019, 7:02
Spildit wrote:
Send the drive to a REPUTABLE data recovery firm for recovery ....
You first posted back on 30/7/2017 ... almost 2 years now ....
The more you mess with the drive the more damage you will cause to it.
Most likely you will not be able to fix it at all even if you were to gain terminal access by TTL adaptor ...
Thanks for time
Don't need data.
wanted to restore drive, was trying to experiment as novice
I guess I give up :)
Users browsing this forum: Google [Bot] and 260 guests
