 Post subject: Harddrive jamming - Help! Videos attached.
PostPosted: June 10th, 2019, 16:03
Hey, I'm new here so hopefully this is in the correct place.
My HardDrive was dropped from a short distance and it started making a noise. When I opened it up the wheel / actual disk wasn't turning, I've managed to get it to turn but it's making a noise / jamming. Any help would be appreciated! Thank you!!
https://youtu.be/ztXhb7nqPqY
 Post subject: Re: Harddrive jamming - Help! Videos attached.
PostPosted: June 10th, 2019, 19:41
Can we assume that your data wasn't worth a few hundred bucks before you opened it? Now that you most certainly damaged the heads and possibly the surface, it will cost a lot more by a professional.
PostPosted: June 11th, 2019, 3:13
Bad thing: opening up the drive in an unclean environment.
Worse thing: running the drive with lid off.
Good thing: from that video it doesn’t look like the damaged heads are sweeping across the surface, causing further media damage.
Probably recoverable, but definitely NOT a DIY job.
PostPosted: June 11th, 2019, 4:20
+1
Lucky. EXTREMELY LUCKY.
PostPosted: June 11th, 2019, 4:21
But now that I see this, I'm not holding my breath.
PostPosted: June 11th, 2019, 5:01
i think there is a 50% chance to recover it yet. if your data is important contact DR center with cleanroom.
PostPosted: June 12th, 2019, 5:35
The reason I opened it was I want he'd some YouTube videos and they done the same.
But I've fuc**d it all up ain't I?
It's got some memories on there along with just random crap like films
I did phone a company but they said £200 I simply don't have that sort of money!
PostPosted: June 13th, 2019, 14:30
Omg! I ruined everything.
I've lost everything!
PostPosted: June 13th, 2019, 14:34
I can take a look, but it’ll be more than £200.
But less than £600 :-)
Users browsing this forum: No registered users and 276 guests
