Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Accessing/Modifying/Dumping M36L0T05 Flash Contents
PostPosted: July 19th, 2019, 14:05
HaQue wrote:
UPDATE:
I received a few things. 1 of the consoles, I think same as OP's luckily.
NOR Removed:
I also received the new FlashCatUSB XPORT, some level converters and the BGA-88 socket:
I will be able to read the Spansion NOR tonight I think, and I will also be making a PCB for the BGA-88 Socket to use on the FlashCatUSB, and do the level conversion, so I don't have to rewire everything all the time. I made a Mock-up in Paint to show how I think it will look:
[attachment=0]XPORT_PCB_BGA88_Protov1.jpg[/attachmaaent]
I have the exact same system as the OP and the second one you got. I was hoping you had away to flash the system and add roms to it. The roms included are a bunch of crud IMHO.
My CHIP information:
M400x2-256A
M36L0T705
0T3ZAQ F2
HHK62 VS
KOR 99 923
M36L0T705
0T3ZAQ W0
HHX49 VS
KOR 99 011
I would take a picture, but the unit is at the house and when by the time i got home for lunch my cell phone was dead. i work for U-Haul so I'm use to my phone being dead by lunch. I'm in the office most of the afternoon so the phone has time to charge.
i again would like to know if any progress is made with the units so we can hack them and switch in and out roms. My kids will also thank you.
PostPosted: July 20th, 2019, 13:11
Yes I made progress, and in the process of writing it up properly, but also identifying which memory range on chip is for which game. I have mapped 19 of the games so far... it is time consuming.
The ROMs themselves are stored in these chip/s but do not store a whole ROM consecutively. for example, the ROM for the game "Golf" is stored on the chip as follows:
NOTES:
* The 16 Byte header that is common for NES ROMs is removed.
* There is no optional 128 Byte Title DATA at the end.
0x009D4000 - 0x009D7FFF (length 0x4000) [1 16k bank of Program Data] code for game
0x0090C000 - 0x0090DFFF (length 0x2000) [1 8k bank of Character DATA] sprites for game (16 Bytes each sprite)
here is what the 8k bank of sprites look like:
Here is a zoomed in section of the different sprites (sprites are stored out of order and multipl "tiles" can be used to make up a sprite in the game
There are a couple of strange things with these units I will document later.
The issue with these will be easy access to ROMs on the chip as regular legit Nintendo consoles of these re-released type have a usb port for easy switching of the roms with a homebrew utility. These are different.
PostPosted: July 20th, 2019, 17:43
I notice that many of the games are duplicated.
PostPosted: September 7th, 2019, 19:13
Now that I am at the end of my seat, what has come of this??? I have the same Nock-off NES as OP's... any progress?
PostPosted: September 8th, 2019, 10:24
What specifically did you want to see come out of this? I think most of the progress has been documented, though I did buy another 4 different units of varying specs. Just because they were so cheap, each under AU$20. they are all pretty much the same.. a tiny motherboard with some kind of NOR flash, either parallel or Quad SPI in the newer ones. Very easy to read with the FlashCatUSB (XPORT Version).
They all have ROMs blatantly pirated or with some hackiness going on like sprites from one game in a different game.
swapping out NES Roms wont be as simple as the legit Nintendo because of no USB port.
If you mean reading the CFI flash with 1.8v logic, then I think I have everything I need, level converters, power supplies etc, just have been too busy/lazy/sidetracked to hook it up..
PostPosted: September 17th, 2019, 15:42
HaQue I can't thank you enough for going to such lengths for this question of mine. I apologize for having been absent so long, in July I went on vacation and life has been insane since. I just remembered last night half asleep about this project and that you were working on it and I felt awful. I would have mailed you my console to save you the money, but it's too late now I suppose.
Originally I was obviously looking at this with an oversimplistic view of it, hoping I could simply interface with the chip and work with it as if it were a usb flash drive, with some sort of translation software. I was hoping this was commonplace and someone had already done all the hard work. You've managed to dump the contents which is great! I would never have gotten that far.
If I understand correctly this (these devices) is all very bodgy and they're not regular rom files, nor are the files even laid out similarly. There doesn't seem to be any easy way to simply remove their roms and substitute my own :(
In the end there are many easier ways to accomplish that, but I thought there might have been potential for these little cheap consoles to do that.
I thank you again for going to such lengths for my request. I am very impressed!
PostPosted: September 18th, 2019, 12:42
welcome back. Yes quite fun actually!
for under $20 for most of these units, quite a good platform to hack around on. I wish I had some more time to dig in a bit more.
Fun fact - playability of these things are surprisingly good. Beats the Donkey Kong multiscreen games we had years ago.
no real easy way to add your own games, like the proper Nintendo hack.
I might get around to blogging all this one day.
PostPosted: September 19th, 2019, 8:21
looks like another contender to get de-warranty'd
https://www.ebgames.com.au/product/sega/217654-sega-mega-drive-mini?utm_source=edm&utm_medium=email&utm_content=header&utm_campaign=edm_20190919_oa_segamegadrivemini_outnow
The iconic SEGA Mega Drive console
The SEGA Mega Drive console defined a generation of gaming returns in a slick, miniaturised unit. The SEGA Mega Drive Mini console is loaded with 42 legendary games including:
•Sonic the Hedgehog
•Ecco the Dolphin
•Castlevania: The New Generation
•Space Harrier 2
•Shining Force
•Dr. Robotnik's Mean Bean Machine
•ToeJam & Earl
•Comix Zone
•Altered Beast
•Gunstar Heroes
•Castle of Illusion Starring Mickey Mouse
•World of Illusion Starring Mickey Mouse and Donald Duck
•Thunder Force III
•Super Fantasy Zone
•Shinobi III
•Streets of Rage 2
•Earthworm Jim
•Sonic the Hedgehog 2
•Probotector
•Landstalker
•Mega Man®: The Wily Wars
•Street Fighter II’®: Special Champion Edition
•Ghouls ‘n Ghosts®
•Alex Kidd in the Enchanted Castle
•The Story of Thor
•Golden Axe
•Phantasy Star IV: The End of the Millennium
•Sonic the Hedgehog Spinball
•Vectorman
•Wonder Boy in Monster World
•Tetris®
•Darius
•Road Rash II
•Strider
•Virtua Fighter 2
•lisia Dragoon
•Kid Chameleon
•Monster World IV
•Eternal Champions
•Columns
•Dynamite Headdy
•Light Crusader
Includes:
•SEGA Mega Drive Mini console
•2 Controllers
•USB Power Cable
•HDMI Cable
Features:
•Miniature SEGA Mega Drive replica
•Includes 42 legendary games
PostPosted: September 19th, 2019, 17:00
Ya they do run pretty well, it's a shame it's so difficult to modify them, but I'm glad it was fun.
If you do, feel free to link your blog I'd love to read about it.
The Sega looks cool, expensive though!
Raspberry Pi is so much cheaper and more versatile, but it doesn't have the look at least out of the box.
PostPosted: September 19th, 2019, 20:19
Thats why you 3D print an enclosure or make a clear cool perspex one to get something unique ;-)
PostPosted: September 23rd, 2019, 14:25
hehe I agree and I have done, but I don't want to assume everyone else has a 3D printer :P
PostPosted: January 4th, 2020, 2:29
So, we can't/won't be able to swap out the roms? My ex-wife picked 2 of these babies for $24.00 USD at an Auction House back in June or July when I first posted. She asked me to take it to my house and make sure it had actual NES games, as her sister-in-law's device had knock off games that they had never heard of. Just keep me posted if there is away to swap out ROMs and thank you for all the hard work you've done so far.
PostPosted: January 5th, 2020, 22:35
I really don't think so unless you dump the rom, hex edit it and rewrite it. but the work in testing, finding proper locations in the dump etc would not be much fun at all.
PostPosted: October 26th, 2021, 22:58
Hello guys, i saw that you successfully dump the data from those chips, in my case i got a new Retro FC mini console, this one was a bargain soooo, i bought it, well story short, it has a blob, also the M36L0T7050T3ZAQ, so i was trying to read the contents and learn how this one works to hack the roms and the basic landing screen that is soo annoying, i tried with my raspberry to identify the port and other things about the board, but looks like the usb port does nothing else than receive power and send power to the dummy extra 2 player controller included in the package, so i was wondering if you would be so nice to provide information about how did you manage to dump the contents and more important if you guys were able to flash it again with different data.
Cheers.
File comment: board
File comment: Quality
PostPosted: December 5th, 2023, 22:35
I didn't realise there was a new post, sorry.
I will add an answer just for completeness, though may not be relevant anymore!
The FlashcatUSB XPORT should be able to read that chip, though you would need to do one or more of the following:
1) check datasheet of actual chip for voltage and pinout
2) if 1.8v, make an adapter with logic level converters
3) wire it up on a board to interface with XPORT.
I have just started re-visiting this and have received some level converters, and started designing a board that will go straight on XPORT.
Forget the BLOB! It is likely just an FPGA emulator, and offers no value to pursue getting into it.
flashing with different data, while theoretically possible, isn't really viable. It has been discussed already in previous posts.
PostPosted: December 8th, 2025, 21:16
Thank you, yes i was able to read the data form the flash, i used a RPi0W it was a bit slow but it worked, the sad part, i was planning to update the content and add more functions and kind of mod the usb entrance to allow read write actions, but while i was reading the binaries and the small amount of info about these roms and how the worked i realized it will take me way more time, and it wont be useful, these change every month and the as the picture shows they will just mod the chip over an over and just change the blob to work with the new chip. So not worth the effort.
At the end i reused what i could and created a small linux retrobox using fbdev for the rpi and the components in the handheld.
Thank you community, and i think we can close this out, is not worth the effort.
PS: i have the datasheets, pdfs, looks like that chip is deprecated and the info is not longer available in all countries.
Cheers
PostPosted: December 10th, 2025, 20:07
It was absolutely worth the effort. I enjoyed the research and learnt a bit on the way!
Users browsing this forum: No registered users and 104 guests
