St3000DM001
October 3rd, 2019, 6:51
Good morning everyone, I wanted to ask for help for a hdd seagate st3000dm001 desktop. Due to a broken motherboard I should replace it with an identical one, but the chiop firmware is broken so I can't replace it. I tried reprogramming the new card by simply replacing the number of nights, but it doesn't work. If you need I can post the original firmware of the unit also as an archive for you.
With what software is it possible to change the serial number from file.bin? Thanks. As a counter-insight to the site I can send you the firmware of various disks if you need it.
Corrado
Re: St3000DM001
October 3rd, 2019, 9:06
You need the contents of the original ROM image. It contains adaptive parameters. Without it, the disc can be discarded. Or prepare a very lot of money and contact a specialist.
Re: St3000DM001
October 3rd, 2019, 9:38
Ok the original rom is burn for power problems....
Re: St3000DM001
October 3rd, 2019, 10:54
DFL-ST program correct the serial number?
Re: St3000DM001
October 3rd, 2019, 12:12
Changing.the serial number will not help. The drive will not work.
Re: St3000DM001
October 3rd, 2019, 12:59
Thanks for the reply. So there is no software capable of reconstructing the SPI of this hdd
Re: St3000DM001
October 3rd, 2019, 21:03
There is no software available to reconstruct ROM on your model drive, at least not publicly. Only manual solution by a specialist.
Re: St3000DM001
October 4th, 2019, 18:16
what's your P/N?
Re: St3000DM001
October 5th, 2019, 17:22
S/N is Z1F2SJ2T
Re: St3000DM001
October 6th, 2019, 1:04
Senza la rom originale direi che non si può fare , fatte salve rare eccezioni e comunque ti occorre uno specialista. Sei sicuro che il chip rom sia morto ? Come lo hai testato ? Oppure ha segni evidenti di bruciature ?
Re: St3000DM001
October 6th, 2019, 6:02
Lavoro nel settore di microelettronica da 26 anni... La scheda ha ricevuto una scarica attraverso alimentatore fulminato da un temporale.
La scheda è da buttare il chip è stato da me dissaldato ma non risponde nel programmatore.
Cosa intentdi per rari casi? Ho 4-5 firmware si questo modello di hdd, ho già provato diverse programmazione, il disco con nuova board fa sipin-up ma leggendolo da seriale con i comandi ata, non da errori sul servo, ma si blocca con la dicitura che adesso non ricordo esattamente ma confernma un errore sul firmware o sul seriale.
Re: St3000DM001
October 6th, 2019, 6:13
corrado@exformat.com wrote:Ok the original rom is burn for power problems....
very odd
Re: St3000DM001
October 6th, 2019, 7:14
Nella rom ci sono dei parametri specifici per ogni singola unità , senza quella originale è praticamente impossibile ottenere l'accesso al disco, qualcuno in questo forum che se non vado errato ti ha già risposto, credo sia pepe , ha ottenuto l'accesso in una condizione simile ma onestamente non conosco i dettagli , mi è stato raccontato . In questi casi purtroppo bisogna contattare qualcuno che fa questo di mestiere e neanche uno qualsiasi ma uno che ha già affrontato un problema di questo tipo . Fosse stato un wd sarebbe stato difficile ma con certezza di sarebbe potuta ricreare la rom ma con un Seagate è tutta un'altra storia. Se vuoi puoi mandarmi il caso, lo analizzerò per te ma ti avverto che è molto complesso .
Re: St3000DM001
October 6th, 2019, 7:16
very odd
Oh no , in my experience I haved many similar case with chip rom un fault , it's rare but non impossible
Re: St3000DM001
October 6th, 2019, 14:57
magnetepazzo wrote:Nella rom ci sono dei parametri specifici per ogni singola unità , senza quella originale è praticamente impossibile ottenere l'accesso al disco, qualcuno in questo forum che se non vado errato ti ha già risposto, credo sia pepe , ha ottenuto l'accesso in una condizione simile ma onestamente non conosco i dettagli , mi è stato raccontato . In questi casi purtroppo bisogna contattare qualcuno che fa questo di mestiere e neanche uno qualsiasi ma uno che ha già affrontato un problema di questo tipo . Fosse stato un wd sarebbe stato difficile ma con certezza di sarebbe potuta ricreare la rom ma con un Seagate è tutta un'altra storia. Se vuoi puoi mandarmi il caso, lo analizzerò per te ma ti avverto che è molto complesso .
Ok ti ringrazio, sto contattando direttamente seagate per avere un resoconto poi se non ne esco vedo di trovare un datarecover serio, i dati presenti sul disco sono importanti ma una parte di backup dovrebbe esserci, devo valutare bene il rapporto spesa tempi o rifare parte dei lavori. Si tratta di set cinematografico, proprio su un problema di backup giornaliero. Non posso recuperare dati parziali. In caso gireremo nuovamente le scene mancanti.
Grazie
Re: St3000DM001
October 6th, 2019, 16:41
Un lavoro del genere può costare anche più di 1000 euro, più è complesso più è costoso. Spero tu risolva
Re: St3000DM001
October 6th, 2019, 17:06
Si più o meno sono i prezzi che ci sono in giro. Trovare i migliori potrebbe essere il problema
Re: St3000DM001
October 7th, 2019, 17:00
besides a lot of words in italian you still haven't told me the PN... I have recovered F3 roms but it depends on some factors...
Re: St3000DM001
October 8th, 2019, 8:59
pepe wrote:besides a lot of words in italian you still haven't told me the PN... I have recovered F3 roms but it depends on some factors...
things is the PN thanks
Re: St3000DM001
October 8th, 2019, 9:57
please read PN from label. It should look like 1CH166-xxx or 9YN166-xxx, etc
