Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: St3000DM001
PostPosted: October 9th, 2019, 19:15
Confermo, i seagate con rom persa sono un vero problema, pochi al mondo sanno come ricostruirla e pepe è uno di questi.
My firmware database:
PostPosted: October 15th, 2019, 11:04
Holee Original Rom is recover, very lucky work..
But new error present.
My error is:
RECOV Servo Op=0100 Resp=0005
Spin Up Complete
Elapsed Time 10.325 secs
F3 2>/
F3 T>m0,6,2,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0000008
8, File Error 0000FFFF
PostPosted: October 15th, 2019, 11:05
Miracolosamente una volta dissaldata la rom è stato possibile leggerla, era in corto sulla board originale ma lei si è salvata.
PostPosted: October 15th, 2019, 11:09
Ho copiata è installata su una nuova board. il disco per da ancora problemi, spero non si sia rotto l'amplificatore interno delle testine. Comunque questi sono gli errori:
F3 T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 9 0
Head 0: entries 1 slips 0
Head 1: entries 0 slips 0
Head 2: entries 0 slips 0
Head 3: entries 0 slips 0
Head 4: entries 0 slips 0
Head 5: entries 0 slips 0
Total Entries 1 Total Slips 0
F3 T>V2
System Slip Defect List
0 0 0 0 0 0 0 34ADA 0 FFFFFFFF 0
62B42 DF8E DF8E 0 1 0 1 35269 0 FFFFFFFF 70AD0
C5684 DF8E 1BF1C 0 2 0 2 33C61 0 FFFFFFFF E15A0
1281C6 DF8E 29EAA 0 3 0 3 379E2 0 FFFFFFFF 152070
18AD08 DF8E 37E38 0 4 0 4 34DAF 0 FFFFFFFF 1C2B40
1ED84A DF8E 45DC6 0 5 0 5 336C1 0 FFFFFFFF 233610
25038C DF8E 53D54 168 0 0 6 34C42 0 FFFFFFFF 2A40E0
2B2ECE DF8E 61CE2 168 1 0 7 353D1 0 FFFFFFFF 314BB0
315A10 DF8E 6FC70 168 2 0 8 33DC9 0 FFFFFFFF 385680
378552 DF8E 7DBFE 168 3 0 9 37B4A 0 FFFFFFFF 3F6150
3DB094 DF8E 8BB8C 168 4 0 A 34F17 0 FFFFFFFF 466C20
43DBD6 DF8E 99B1A 168 5 0 B 33829 0 FFFFFFFF 4D76F0
Head 0: entries 2 slips DF8E
Head 1: entries 2 slips 1BF1C
Head 2: entries 2 slips 1BF1C
Head 3: entries 2 slips 1BF1C
Head 4: entries 2 slips 1BF1C
Head 5: entries 2 slips 1BF1C
Total Entries C Total Slips 99B1A
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
PostPosted: October 15th, 2019, 11:13
Come ti avevo anticipato se vuoi posso occuparmi del tuo caso, se ti va possiamo discuterne anche in privato
PostPosted: October 19th, 2019, 15:21
Help me...
who helps me. if I send you my firmware, can anyone try to remap the heads with a few different options?
PostPosted: October 19th, 2019, 15:58
F3 T>m0,6,2,,,,,22
Why did you apply this command?
PostPosted: October 20th, 2019, 4:50
labtech wrote:
F3 T>m0,6,2,,,,,22
not work this command. disk Busy.
PostPosted: October 20th, 2019, 4:53
Post the terminal log , Power in the drive with a clean log and post it please .
PostPosted: October 20th, 2019, 5:44
today it goes like this, sometimes it overcomes the first step and arrives at the command line.
NB already change the heads twice. Unfortunately, the first course is slightly scratched, I don't know the treble because they haven't been disassembled. The work was done in a clean room.
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1840 0071 06CC 4480 0008 0000 0000 0000 0D32 0000 0000 0000 0000
0000 0000 0000 4340 D934 FFFF 2000 2269 0000 0004 F6A5 0004 F6A5 0000 2247 0000
0020 001A 0007 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame 2080 0074 06CC 4400 0008 0000 0000 0000 0D4A 0000 0000 0000 0000
0000 0000 0000 4340 D934 FFFF 2000 2269 0000 0004 F6A5 0004 F6A5 0000 007F 0004
0020 001A 0004 0000
PostPosted: October 20th, 2019, 5:47
this is dump of SPI
ROM ORIGINALE BARRACUDA SARA.zip [346.92 KiB]
Downloaded 409 times
PostPosted: October 20th, 2019, 7:49
Fail servo , head issue
PostPosted: October 20th, 2019, 7:55
This is new head...double change and test head.
PostPosted: October 20th, 2019, 8:49
if plate have important scratches the heads break instantly. Install the head in donor and verify if work
PostPosted: October 20th, 2019, 8:57
scratch is very minimal in the plat only microscope view this. I test the head only in donor thanks
PostPosted: October 20th, 2019, 8:59
If head work in donor you can try a virtual start with pc3000 o mrt
PostPosted: October 20th, 2019, 9:05
I have to buy these software, I've been thinking about it for a while, now I don't have them. Data recovery is not my main activity. But I have been an electronics and micoro electronics expert for about 26 years. I worked in a clean room for a year.
PostPosted: October 20th, 2019, 9:11
No way, without this tools you don't make a data recovery. I think you have a head issue , test the head.
PostPosted: October 20th, 2019, 9:22
ok I test the head. Please advice pc3000 or mrt?
PostPosted: October 20th, 2019, 11:56
It's indifferent for this case, but it's no easy to use and to make a virtual start you need virtual 3d for your firmware .
