 Post subject: WD3200AAKS-00UU3A0 - spins down and reset after 40 seconds
PostPosted: October 21st, 2019, 6:17
Hello guys. I've got some drives to study and I'm here with another one that never occurred to me, and didn't find anything on forums.
This WD3200AAKS-00UU3A0 starts apparently ok when turned on with an isolated power supply. But after 40 seconds (sometimes more) it spins down and start again.
Using MRT I have the same behavior, with BSY led on during all time.
Already changed PCB, still the same.
Don't know what to try next.
Thank you so much for all your kind help.
 Post subject: Re: WD3200AAKS-00UU3A0 - spins down and reset after 40 secon
PostPosted: October 21st, 2019, 8:19
Block SA and check modules. 32 for example.
odzyskiwanie danych
PostPosted: October 21st, 2019, 20:14
Thank you so much for your reply, and I'm really sorry for my newbie questions.
Had blocked SA and performed a diagnosis. Had this output:
Technology mode key : ..........................: OK
Enter diagnostic mode. Please wait for completing diagnosis .
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: 63B0
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 192 Kb
ROM version : ..................................: 00.0JB
ROM generation : ...............................: 00.0JB
Link table version : ...........................: 03.0B
ROM Firmware version : .........................: 0000000J
ROM Modules:
Flash ROM dir reading : ........................: OK
The SA entry address : .........................: closed
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
Load SA translator : ...........................: OK
Close 02 module ...
Get 02 access information : ....................: OK
Check 02 access data : .........................: OK
Close 02 module : ..............................: OK
Open 02 module ...
Open 02 module : ...............................: OK
Open 411 module ...
Get 411 access information : ...................: OK
Check 411 access data : ........................: OK
Open 411 module : ..............................: OK
load 01...
load 01 to HDD RAM...
The data source : ..............................: HDD
Get 01 module from HDD : .......................: OK
Load module list : .............................: OK
Load LDR : .....................................: Err
Load 02 module to HDD RAM : ....................: Failed
Zone allocation table : ........................: Err
Open SA access ...
Get SA access information : ....................: Failed
Failed to read the 01 module. Diagnosis cancelled!
Now we have the modules list, but I can't access any of those modules.
I really appreciate any other help. Thank you again.
PostPosted: October 22nd, 2019, 7:14
I believe I'll need a LDR for this one, right?
Does anybody here have it?
Thank you for any help.
PostPosted: October 22nd, 2019, 7:25
There is a Tahoe LT 0000000J over at HddSurgery https://firmware.hddsurgery.com/index.php
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 22nd, 2019, 7:41
Mikippp
>ROM version............................. : 00.0JB
>ROM generation.......................... : 00.0KB
>Link table version...................... : 03.0B.
>Consolidated ROM version................ : 0000000J
11.zip [389.62 KiB]
Downloaded 402 times
PostPosted: October 22nd, 2019, 7:46
digisupport, Thank you for your reply :)
Mikippp, Thank you so much for sharing :)
PostPosted: October 31st, 2019, 14:38
Can u see modules?
Log says mod 02 not loading.
Try to find mod 2 with BY ID and By Copy 0/1 . Maybe one of them good.
Sometimes it's occur when bad head
Sexy Womans from your town
