 Post subject: Seagate Barracuda 7200.7 Dead
PostPosted: October 24th, 2019, 13:07
I've got an old (2005) IDE Barracuda 7200.7 160gb. Model ST3160021A. No sign of life at all. It has no value but I just want to practice on it to see if I can get it back to life.
Is there a tvs diode, I can remove to see if that's the problem?
I've attached a picture of the board but can't tell where the diode is. There is no obvious burnt area or any other sign of damage.
 Post subject: Re: Seagate Barracuda 7200.7 Dead
PostPosted: October 24th, 2019, 13:22
Check those two with a multimeter.
http://www.rescue-it.se
PostPosted: October 24th, 2019, 13:33
Not sure which is positive or negative on the diodes. Results are...
negative probe on top end of larger diode gives a reading of around .645
Opposite gives 1.99
negative probe on left of smaller diode gives 1.42
opposite gives .556
Either way they seem ok don't they?
PostPosted: October 24th, 2019, 13:37
The connection points to the drive on the underside of the board are a bit discoloured. Is it worth cleaning them gently with an eraser?
PostPosted: October 24th, 2019, 13:54
Do you measure with no power and MM on 200M ohm range?
You can clean them, no problem
PostPosted: October 24th, 2019, 14:34
Yes, I did.
I'll try cleaning the connection points and see if that helps.
Any suggestions as to what else might be worth trying?
PostPosted: October 24th, 2019, 14:39
Easy way to check TVS diodes is to use a MM with a “beeping” continuity mode.
If the MM beeps then the TVS is bad.
PostPosted: October 24th, 2019, 14:40
Tried that as well. No beeping..
PostPosted: October 24th, 2019, 15:09
Checked the one above as well...6.8 35v?
PostPosted: October 24th, 2019, 15:12
No beep in continuity mode. Similar readings to large diode near it..
PostPosted: October 24th, 2019, 15:48
That is a 6.8uF 35V capacitor.
PostPosted: October 24th, 2019, 16:12
Measure the voltages at the two 6-pin ICs (what are their markings?) and the F6P02 MOSFET.
The negative supply for the preamp appears to be at the rear of the PCB. Measure the voltages on the adjacent capacitors. (What are the markings on the IC?)
Tip: How to take a good PCB photo:
http://www.hddoracle.com/viewtopic.php?f=112&t=120
Tutorial - Linear and Switchmode Regulators used in HDDs:
http://www.hddoracle.com/viewtopic.php?f=59&t=231
Datasheets for HDD semiconductors, regulators, op-amps:
http://www.hddoracle.com/viewtopic.php?f=100&t=94
PostPosted: October 24th, 2019, 16:13
Thanks for the help
PostPosted: October 24th, 2019, 16:19
The stripe is the cathode. It is also marked with a "v" on the PCB. Current flows from anode to cathode.
https://en.wikipedia.org/wiki/Diode
PostPosted: October 25th, 2019, 8:39
Result... Cleaning the connection points on the pcb seems to have fixed the problem. The disk now boots up and I can access the data on it...
PostPosted: October 25th, 2019, 12:56
Yep, and it's part of the 12v power rail...
PostPosted: October 25th, 2019, 12:57
Nice :D :good: Congrats.
PostPosted: October 25th, 2019, 13:44
… which means it is connected in parallel with a TVS diode ...
PostPosted: October 26th, 2019, 5:36
Nice! :-)
PostPosted: October 26th, 2019, 15:09
I assume you mean the HDA pads. What happens if you isolate the HDA with a business card?
Users browsing this forum: No registered users and 86 guests
