 Post subject: WD WD20NMVW access problem
PostPosted: October 27th, 2019, 14:16
Hello friends
Help
Disk is running
drive cannot be accessed. No partition appears.
What is the solution because it is usb?
There are 4 more cases such as wd usb.
 Post subject: Re: WD WD20NMVW access problem
PostPosted: October 27th, 2019, 14:36
Convert to SATA interface for precise diagnosis.
PostPosted: October 27th, 2019, 14:41
+1 :good:
Use Sata Pcb 771960
http://www.rescue-it.se
PostPosted: October 27th, 2019, 14:42
Not sure what all that excess solder splatter on the underside is all about?
Have you tried connecting the drive with a usb2 type cable? One used with an android phone would do the job. Sometimes even if the usb3 side of the socket/circuit is damaged the usb2 side still works.
Users browsing this forum: Majestic-12 [Bot], mima85 and 74 guests
