Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: 3.5" Toshiba's
PostPosted: November 24th, 2019, 13:01
Hello fzabkar,
you're amazing. Removing the diode D703 fixed the HDD. Thank you so much!
First I was worried removing the diode, because in an earlier post it was mentioned that this diode isn't a TVS. So I was not sure if I was allowed to simply remove it.
Note:
I also measured fuse "4" and it was still working. The diode's pads in-circuit showed the same results, as measuring directly on the components.
Users browsing this forum: Google [Bot] and 40 guests
